    [Plugin] Slicer5
    338 Posts 83 Posters 394.1k Views 82 Watching
    • TIGT
      I have now added the 'Txt' ttf font in a zip file onto the end of the main download page... read the notes with its link, if you want to download it...
      zip http://forums.sketchucation.com/download/file.php?id=81087
      on page http://forums.sketchucation.com/viewtopic.php?p=374969#p374969
      • OxerO
        Oxer
        @tig said:
        As far as the translation goes... I've no plans to translate [deBabelize] it... not yet... BUT if you want to post your translation strings, then I can use them when I do [for v5.11+ ?] ๐Ÿ˜•
        I have translated the rb files but if you want i can create the deBabelize file with spanish language for futures updates.
        Thanks again!!
        http://www.oxervision.blogspot.com/
        • TIGT
          Oxer
          Thanks, but language version of each update become unwieldy.
          Please don't post an ES version of the .rb file !
          For future deBabelizer integration I need a ES.lingvo file***
          I can adjust the file name to suit.
          I'll also make the initial matching EN-US.lingvo from scratch anyway...
          I think you know the format for the lingvo files IF you want to make one.
          A word or phrase on each line thus:
          The cat.<==>El gato. A dog.<==>Un pero.
          When deBabelizing the strings I often adjust the actual code's strings anyway, so you need not be too pedantic about every last 'palabra'...
          ๐Ÿ˜‰
          ***I might be able to get the thing deBabaleized next week so if you want to simply PM me your translated .rb file, it would save you making the ES.lingvo at all... ๐Ÿ˜ฎ
          • OxerO
            Oxer
            OK, i send you the rb files for PM.
            • TIGT
              Here's v5.11 http://forums.sketchucation.com/viewtopic.php?p=374969#p374969
              There are several minor adjustments to dialog and status-bar text etc.
              The tool is now fully 'deBabelized' into other languages [requires deBabelizer.rb to be in the Plugins folder, this file is included in the archived set you download]; various lingvo files are included in this tool's subfolder. These lingvo files [except the ES one which has already been edited by Oxer (thanks!)] will need some "improvements", please post your suggested improved lingvo file, OR even a brand new lingvo file for your own locale... Over time they'll get incorporated into new update sets...
              The 'Txt.ttf' Font [zipped] is now added to the available downloads in the first post [for those of you who still need it!]...
              Also the soon-to-be-deprecated 'PLATFORM' is now replaced by 'RUBY_PLATFORM' for cross-platform compatibility.
              • OxerO
                Oxer
                You're rapid like a ray, thanks again TIG. ๐Ÿ‘
                • TIGT
                  @miki71ita said:
                  hi TIG!... I downloaded the last version 5.11 and....You wrote 'The best Plugin all over the world!!!' for me!!! ๐Ÿ˜
                  But I use the old 5.5v!.. And I'd like to know a tip... Your script (5.5v) makes the menu: 'Plugins' and the item: 'Slicer5' inside it.
                  How can I simulate the press of this item by ruby code to start your script from my small personal script, without using manually the mouse click on it?.. Tanks a lot and good job!!! ๐Ÿ‘
                  To make a shortcut key that works for any tool [even scripts] you simply open Window > Preferences > Shortcuts, filter for 'Slicer' [or whatever it is called in your locale if you have the more recent deBabelized version]. The available list of tools will be reduced to just those containing 'Slicer'. Pick the one you want and assign a shortcut key to it.
                  Don't use numbers as they are used for inputting lengths etc, and some others are already used like S for Scale and Ctrl+S for Save. Repeat if you want to add other shortcuts to other tools... OK to close and try your shortcut - if you don't have a suitable selected group etc the error message should be the same if if you ran it from a Plugins-menu item or Slicer5-toolbar button click. ๐Ÿค“
                  PS: Why haven't you upgraded to v5.11 ? It is more stable has a few minor issues fixed AND offers several new/improved tools, like Slotter and Audit...
                  ๐Ÿ˜•
                  • TIGT
                    @miki71ita said:
                    OK thanks for Tip, but I'd like to launch your script from ruby code into my small script....
                    maybe exist a SU ruby command to select and virtually push a specific button inside the Slicer5's Toolbar...? or to select your script from Plugin menu.....?? or something similar..! ๐Ÿ’š ๐Ÿ˜ณ
                    Read the first part of the module in TIG-Slicer.rb and see how the commands are called for the menus and toolbar-buttons.
                    Simply replicate those in your own code e.g.
                    cmd=UI::Command.new(S5){self::Slicer.new()}
                    where you do
                    S5="Slicer5_inside_my_code" cmd=UI::Command.new(S5){**TIG::Slicer.new()**}
                    make sure that it loads after Slicer.rb has loaded by naming if after it alphabetically OR include require 'Slicer.rb' at the start of your code.
                    • TIGT
                      I did embolden the 'important part':
                      If you type/copy+paste that in the Ruby Console you'll see it starts 'Slicer5'.
                      If nothing is selected it produces the same error message as running it from the menu or the toolbar might.
                      So your own code either needs to ensure something suitable [i.e. ONE 'solid' group/component] is selected when it gets to that line of 'Slicer' code, or just before that line you need to use something like:
                      Sketchup.active_model.selection.clear Sketchup.active_model.selection.add(object)
                      which will ensure that the group/component-instance which the reference ' object' points to is the only thing selected when the 'Slicer' code kicks in... ๐Ÿค“
                      • M
                        miki71ita
                        ....amazing! You have a solution for everything .... Thank you so much TIG!!! ๐ŸŽ‰ ๐Ÿ˜‰ ๐Ÿ‘
                        • M
                          miki71ita
                          ๐Ÿ˜’ Sorry, but I'm a very super beginner in SU and ruby-script language.....!!! And so my question is:
                          to run your 'Slicer5' plugin I can use the 'Plugins-menu item' or 'Slicer5-toolbar button click'....
                          • M
                            miki71ita
                            ok thanks for Tip, but I'd like to launch your script...
                            • M
                              miki71ita
                              How can I simulate the...
                              • M
                                miki71ita
                                About the Bug...
                                • M
                                  miki71ita
                                  ๐Ÿ˜ณ Hi people... I have a problem with Slicer5 v5.5....
                                  • guanjinG
                                    guanjin
                                    Hello, I am a Chinese user, I am Chinese language translation tools for the Chinese language how to use the default tool, thank you!
                                    I come from China, is to learn
                                    • TIGT
                                      Do you understand how to make a 'lingvo' file ?
                                      Here an overview...
                                      Find your 'locale' id, in the Ruby Console thus:
                                      Sketchup.get_locale.upcase
                                      For Chinese it'll probably be
                                      ' ZH-CN'
                                      Make a copy of the TIG-SlicerEN-US.lingvo file that is in the TIG-Slicer subfolder, within the Plugins folder.
                                      Name this copied file to match that, thus:
                                      TIG-Slicer**ZH-CN**.lingvo
                                      Edit that new lingvo file using a plain-text editor like Notepad++.exe.
                                      A lingvo file contains words or phrases; one 'set' per line.
                                      In the English version the original word or phrase, and its translation are the same.
                                      There is a special symbol separating the two parts
                                      For example...
                                      Slicing tool**<==>**Slicing tool
                                      Make your translation for the word or phrase.
                                      Replace the right-hand version.
                                      For example in 'Simplified Chinese' you could use something like...
                                      Slicing tool**<==>**ๅˆ‡็‰‡ๅทฅๅ…ท
                                      Repeat your translations as desired...
                                      Save the lingvo file.
                                      When Sketchup restarts it should find this new lingvo file, and because it matches your locale it will translate any English matching words or phrases that it finds, using your locale's translations... Any words that you do not translate remain the same; so if you leave the line as
                                      Slicer5<==>**Slicer5**
                                      Your menu items etc will then say ' Slicer5' even though they will use Chinese translations for other words you might have given translations to...
                                      Tip: You might need to 'convert' the lingvo file to a UFT-8 encoded type, to get the Chinese characters to be correctly displayed ๐Ÿ˜• You can easily do that with Notepad++.exe.
                                      ๐Ÿค“
                                      • guanjinG
                                        guanjin
                                        Here an overview...
                                        ' ZH-CN'
                                        For example...
                                        ๐Ÿค“
                                        Thank been resolved, there is a problem, slice tile can not be achieved, the previous version can, thank you!
                                        • TIGT
                                          Please explain ore clearly - I don't fully understand you... ๐Ÿ˜•
                                          Are you getting error messages in the Ruby Console ?
                                          What is failing ?
                                          Is this after you have messed with a lingvo file ?
                                          Does it work if you temporarily remove the lingvo file from the subfolder ?
                                          Which version worked ?
                                          Which version fails ?
                                          ๐Ÿ˜•
                                          • guanjinG
                                            guanjin
                                            What is failing ?
                                            ๐Ÿ˜•
                                            Version 5.11, can not be achieved slice tile, without any prompting!
                                            • 6
                                            • 16
                                            • 17
                                            • 4 / 17
