    [Plugin] Slicer5
    338 Posts 83 Posters 394.1k Views 82 Watching
      Here's v5.11 http://forums.sketchucation.com/viewtopic.php?p=374969#p374969
      There are several minor adjustments to dialog and status-bar text etc.
      The tool is now fully 'deBabelized' into other languages [requires deBabelizer.rb to be in the Plugins folder, this file is included in the archived set you download]; various lingvo files are included in this tool's subfolder. These lingvo files [except the ES one which has already been edited by Oxer (thanks!)] will need some "improvements", please post your suggested improved lingvo file, OR even a brand new lingvo file for your own locale... Over time they'll get incorporated into new update sets...
      The 'Txt.ttf' Font [zipped] is now added to the available downloads in the first post [for those of you who still need it!]...
      Also the soon-to-be-deprecated 'PLATFORM' is now replaced by 'RUBY_PLATFORM' for cross-platform compatibility.
      • OxerO
        Oxer
        You're rapid like a ray, thanks again TIG. ๐Ÿ‘
          @miki71ita said:
          hi TIG!... I downloaded the last version 5.11 and....You wrote 'The best Plugin all over the world!!!' for me!!! ๐Ÿ˜
          But I use the old 5.5v!.. And I'd like to know a tip... Your script (5.5v) makes the menu: 'Plugins' and the item: 'Slicer5' inside it.
          How can I simulate the press of this item by ruby code to start your script from my small personal script, without using manually the mouse click on it?.. Tanks a lot and good job!!! ๐Ÿ‘
          To make a shortcut key that works for any tool [even scripts] you simply open Window > Preferences > Shortcuts, filter for 'Slicer' [or whatever it is called in your locale if you have the more recent deBabelized version]. The available list of tools will be reduced to just those containing 'Slicer'. Pick the one you want and assign a shortcut key to it.
          Don't use numbers as they are used for inputting lengths etc, and some others are already used like S for Scale and Ctrl+S for Save. Repeat if you want to add other shortcuts to other tools... OK to close and try your shortcut - if you don't have a suitable selected group etc the error message should be the same if if you ran it from a Plugins-menu item or Slicer5-toolbar button click. ๐Ÿค“
          PS: Why haven't you upgraded to v5.11 ? It is more stable has a few minor issues fixed AND offers several new/improved tools, like Slotter and Audit...
          ๐Ÿ˜•
            @miki71ita said:
            OK thanks for Tip, but I'd like to launch your script from ruby code into my small script....
            maybe exist a SU ruby command to select and virtually push a specific button inside the Slicer5's Toolbar...? or to select your script from Plugin menu.....?? or something similar..! ๐Ÿ’š ๐Ÿ˜ณ
            Read the first part of the module in TIG-Slicer.rb and see how the commands are called for the menus and toolbar-buttons.
            Simply replicate those in your own code e.g.
            cmd=UI::Command.new(S5){self::Slicer.new()}
            where you do
            S5="Slicer5_inside_my_code" cmd=UI::Command.new(S5){**TIG::Slicer.new()**}
            make sure that it loads after Slicer.rb has loaded by naming if after it alphabetically OR include require 'Slicer.rb' at the start of your code.
              I did embolden the 'important part':
              If you type/copy+paste that in the Ruby Console you'll see it starts 'Slicer5'.
              If nothing is selected it produces the same error message as running it from the menu or the toolbar might.
              So your own code either needs to ensure something suitable [i.e. ONE 'solid' group/component] is selected when it gets to that line of 'Slicer' code, or just before that line you need to use something like:
              Sketchup.active_model.selection.clear Sketchup.active_model.selection.add(object)
              which will ensure that the group/component-instance which the reference ' object' points to is the only thing selected when the 'Slicer' code kicks in... ๐Ÿค“
                miki71ita
                ....amazing! You have a solution for everything .... Thank you so much TIG!!! ๐ŸŽ‰ ๐Ÿ˜‰ ๐Ÿ‘
                  miki71ita
                  ๐Ÿ˜’ Sorry, but I'm a very super beginner in SU and ruby-script language.....!!! And so my question is:
                  to run your 'Slicer5' plugin I can use the 'Plugins-menu item' or 'Slicer5-toolbar button click'....
                    miki71ita
                    ok thanks for Tip, but I'd like to launch your script...
                      miki71ita
                      How can I simulate the...
                        miki71ita
                        About the Bug...
                          miki71ita
                          ๐Ÿ˜ณ Hi people... I have a problem with Slicer5 v5.5....
                          • guanjinG
                            guanjin
                            @tig said:
                            I have now added the 'Txt' ttf font in a zip file onto the end of the main download page... read the notes with its link, if you want to download it...
                            zip http://forums.sketchucation.com/download/file.php?id=81087
                            on page http://forums.sketchucation.com/viewtopic.php?p=374969#p374969
                            Hello, I am a Chinese user, I am Chinese language translation tools for the Chinese language how to use the default tool, thank you!
                              Do you understand how to make a 'lingvo' file ?
                              Here an overview...
                              Find your 'locale' id, in the Ruby Console thus:
                              Sketchup.get_locale.upcase
                              For Chinese it'll probably be
                              ' ZH-CN'
                              Make a copy of the TIG-SlicerEN-US.lingvo file that is in the TIG-Slicer subfolder, within the Plugins folder.
                              Name this copied file to match that, thus:
                              TIG-Slicer**ZH-CN**.lingvo
                              Edit that new lingvo file using a plain-text editor like Notepad++.exe.
                              A lingvo file contains words or phrases; one 'set' per line.
                              In the English version the original word or phrase, and its translation are the same.
                              There is a special symbol separating the two parts
                              For example...
                              Slicing tool**<==>**Slicing tool
                              Make your translation for the word or phrase.
                              Replace the right-hand version.
                              For example in 'Simplified Chinese' you could use something like...
                              Slicing tool**<==>**ๅˆ‡็‰‡ๅทฅๅ…ท
                              Repeat your translations as desired...
                              Save the lingvo file.
                              When Sketchup restarts it should find this new lingvo file, and because it matches your locale it will translate any English matching words or phrases that it finds, using your locale's translations... Any words that you do not translate remain the same; so if you leave the line as
                              Slicer5<==>**Slicer5**
                              Your menu items etc will then say ' Slicer5' even though they will use Chinese translations for other words you might have given translations to...
                              Tip: You might need to 'convert' the lingvo file to a UFT-8 encoded type, to get the Chinese characters to be correctly displayed ๐Ÿ˜• You can easily do that with Notepad++.exe.
                              ๐Ÿค“
                              • guanjinG
                                guanjin
                                Here an overview...
                                ' ZH-CN'
                                For example...
                                ๐Ÿค“
                                Thank been resolved, there is a problem, slice tile can not be achieved, the previous version can, thank you!
                                  Please explain ore clearly - I don't fully understand you... ๐Ÿ˜•
                                  Are you getting error messages in the Ruby Console ?
                                  What is failing ?
                                  Is this after you have messed with a lingvo file ?
                                  Does it work if you temporarily remove the lingvo file from the subfolder ?
                                  Which version worked ?
                                  Which version fails ?
                                  ๐Ÿ˜•
                                  • guanjinG
                                    guanjin
                                    What is failing ?
                                    ๐Ÿ˜•
                                    Version 5.11, can not be achieved slice tile, without any prompting!
                                      Let me try to recast what you said, as I understand it...
                                      Version 5.11, does not make slices, without any error messages...
                                      If has a toolbar and menu items, and you have a saved SKP, with just one group selected, and you run the tool... what happens ???
                                      Because it is working successfully for me [and many hundreds of other users] then it suggests that you have something wrong in your installation.
                                      Please try reinstalling everything.
                                      Ensure that there are no copies of the files that should be in the tool's subfolder inside the Plugins folder by mistake.
                                      There should be two files in the Plugins folder
                                      Slicer.rb deBabelizer.rb
                                      and a subfolder named
                                      TIG-Slicer
                                      containing
                                      TIG-Slicer.rb
                                      and the 8 PNG image files for the toolbar buttons
                                      and the 6 lingvo files...
                                      ๐Ÿ˜•
                                        I've noticed an error with the 'Portuguese' lingvo file that was recently supplied with v5.11
                                        It's incorrectly named 'PO' and it contained no translations anyway ! ๐Ÿ˜ฎ
                                        Here's the correct 'PT' version.TIG-SlicerPT-lingvo.zipExtract it from the zip.
                                        If you want Portuguese translations, please remove the incorrect 'PO' version and add this correct 'PT' one to the tool's subfolder. If your 'locale' is not 'PT' you can always change that part of the name to suit...
                                        • guanjinG
                                          guanjin
                                          Here's the correct 'PT' version.[attachment=0:2ob4u420]<!-- ia0 -->TIG-SlicerPT-lingvo.zip<!-- ia0 -->[/attachment:2ob4u420]Extract it from the zip.
                                          I may not know the expression, films can not be razed to the ground piece, thank you
                                          • guanjinG
                                            guanjin
                                            Here's the correct 'PT' version.[attachment=1:zqav1736]<!-- ia1 -->TIG-SlicerPT-lingvo.zip<!-- ia1 -->[/attachment:zqav1736]Extract it from the zip.
                                            Translated into Chinese, it can not achieve the flattening function, the following documents attached to the Chinese language, thank you! !
                                            [attachment=0:zqav1736]<!-- ia0 -->TIG-SlicerZH-CN.zip<!-- ia0 -->[/attachment:zqav1736]
                                            TIG-SlicerZH-CN.zip
                                            • 16
                                            • 17
                                            • 4 / 17
