    Townhomes
    extensions
    11 Posts 6 Posters 1.7k Views 6 Watching
      remus
      might be worth playing around with the sun position a bit, that could help sort out the highlights problem, not sure how itd affect the render time though.
        sepo
        I would suggest you try noisy and let it run. Your scene would be best suited for it.
        • EdsonE Offline
          Edson
          if you let it run for a while the noise disappears gradually.
          http://www.mahfuz.arq.br
            And don't "wait till it finishes": just save the image when you are already fine with it.
            • EdsonE Offline
              Edson
              a little postprocessing would also do the trick.
                sepo
                If you save render as .hdr you can get more out of it in postprocessing.
                • tinanneT Offline
                  tinanne
                  What is .hdr and what program would you use for PP? I've never seen that extension before?
                  Executive Director : American Society of Architectural Illustrators
                  AIP 30 Competition opens soon. ASAI.org
                  Architectural Rendering
                  • EdsonE Offline
                    Edson
                    when rendering in podium, one of the formats you can save your image in is hdr (a better format for post processing).
                      Yes, and a bunch of other stuff these gurus do there
                      • FrederikF Offline
                        Frederik
                        Honey Dear ( 😆 ), check out the Wikipedia... 😉
                        Hope this made it more clear... 😉
                        Cheers
                        Kim Frederik
                          sepo
                          Sorry for not replying earlier. You can use http://www.hdrlabs.com/picturenaut/ freeware to manipulate your .hdr. Quite easy soft to use.
