    [Plugin] Another Sketchup v1.6.1 Feb 19 2013
    16 Posts 6 Posters 20.3k Views 6 Watching
    • dukejazzD Offline
      dukejazz
      Another_Sketchup v1.6.1
      Copyright Feb 19, 2012
      DukeJazz: by James Cochran
      What is this plugin about, its a
      Project editor: (lite)
      • Auto loads another sketchup with clipboard information.... Gives easy power functionality actions, to the editing of sketchup models, objects, or entities;... The objects can be pull out to a child sketchup and return back to illustrate new details to main project when done.
      It works in the context menu named "Another Sketchup". Just give a right click on any object for automation loading.
      Freely use, and abuse at your own risk. No warranty, Implied
      Has been tested on PC sketchup free, pro 6,7,8 and 8m2.
      Features list:
      • Paste in place (Paste in place or paste)
      • Repaste select (Select, delete and paste)
      • Move select (Move select to another sketchup)
      • Send select (Send select to another sketchup)
      • Send all (Send select all to another sketchup. Restart Entities objects and flushes script plugins)
      • Non selected Move (Clipboard info is sent to another sketchup)
      • Non selected Select (Clipboard info is sent to another sketchup)
      • Select exit (Copy selected then exit sketchup)
      • Select all exit (Copy all then exit sketchup)
      • Non Select exit (Keeps Clipboard then exit)
      (*) Warning this copy is lost, if you use the clipboard before repasting
      Tip 1) If it's, paste in place, to a new SU document and you don't need it just undo once or copy something before starting.
      Tip 2) Also you can edit the Context/file/Toolbar menu there and more idea are inside.
      History:
      Feb 19, 2012 Another_Sketchup v1.6.2_Mac (no paste in place)
      Feb 19, 2012 Another_Sketchup v1.6.1
      -add select all,delete and paste in place
      Dec 26 2012 v1.5.4
      • plugins wrap in Module DJ::pluginsName.methodDJ(name space)
      • @variable format (name space) dj_variable
      • plugins name are in subject and name order (easy to look up)
      • feature toolbar add
      • Big new programs is safe to use, now in module format
      7/23/12
      • Toolbar version
      • move to dj_Plugins folder
      5/20/12
      Another_Sketchup Ver. 1.3
      fix messagebox hand shake problem has been removed
      rename some features to a better fitting names
      full functions context_menu
      uses the plus sys engin
      added two pasting tool
      5/16/12
      Another_Sketchup v1.2a
      KISS... ("keep it simple, sir" approach)
      I basically need only 2 options:
      move select
      select all exit
      the messagebox has been removed
      1/18/12
      Another_Sketchup v1.1
      -rewritten codes for the MAC
      -UI.messagebox("Fixes the nil bug splat") don't remove messagebox.
      -UI.messagebox("Gives you a warning that another sketchup is pasting from -clipboard)
      Download:
      Another Sketchup ver 1.6.2_Mac
      Another_Sketchup ver 1.6,2_Mac.zip
      Another Sketchup ver 1.6.1
      Another_Sketchup ver 1.6.1.zip
      Another Sketchup ver 1.5.4
      Another_Sketchup v1.5.4.zip
      Another_Sketchup v1.5.zip
      Another Sketchup ver 1.3
      dj_another_sketchup v1.3.zip
      Another Sketchup ver 1.2a
      dj_another_sketchup Ver. 1.2a KISS options.zip
      Another_Sketchup v1.0 Bata. DukeJazz Dec 28 2011 downloaded 74 times
      Another_Sketchup v1.0 Bata. DukeJazz Dec 28 2011 downloaded 66 times
      • KrisidiousK Offline
        Krisidious
        pretty kool.... I often use more than one instance of SU... I'll give it a whirl on my Pro 8.
        By: Kristoff Rand
        • dukejazzD Offline
          dukejazz
          Verified it works on the PC with sketchup free, pro, 6,7,8 and 8m2
          Not verified yet on the Mac yet, Let me know if its works for you.
          I may put it in file menu area instead of contxt menu
          • dukejazzD Offline
            dukejazz
            Just release new update for Another_Sketchup
            Ver 1.1 1/18/12
            -rewritten codes to work on the MAC
            -UI.messagebox("Gives you a warning that another sketchup is pasting from clipboard)
            Ver 1.0 12/28/11
            • G Offline
              glro
              This plugin is helpful, but it took me time to understand how to use it
              too many options for me ... and "Another sketchup plus" is even more complicated
              move select
              select all exit
              and this is how i proceed in detail:
              select the detail i want to modify in the first sketchup session window
              right click, "another sketchup > move select"
              the selection disappears from the first sketchup window and a second sketchup session is opened with the selection in it.
              modify the detail as needed; when it is done:
              right click anywhere in the second sketchup session, "another sketchup > select all exit"
              message asks if i want to save modifications (no...)
              i come back to the first sketchup session
              and this is the important step: go the "menu > edition > paste on place (or something similar)"
              the detail appears in its previous position, and with the modifications
              If these options are all that i need, i guess it will be the same for some other sketchup users...
              The only detail that disturbs me is the messagebox when a sketchup session is opened; would there be a way to get rid of it?
              • dukejazzD Offline
                dukejazz
                move select
                select all exit
                ok
                Here your ver of Another Sketchup Ver. 1.2a KISS options:
                I guess it will be the same for some other sketchup users...
                If you need more options
                Edit another_sketchup Ver. 1.2a KISS
                Plugins\dj_another_sketchup\Another_Sketchup_Plus_loader.rb
                def youSU_contextAa
                UI.add_context_menu_handler do |context|
                m = context.add_submenu("Another Sketchup plus")
                m.add_item("Place in place") { youSCF_placer }
                m.add_item("Replace what is selected") { another_place }
                #m.add_item("Duplicater") { another_sumPaste }
                #m.add_item("Duplicate all") { another_copyAllPaste }
                #m.add_item("Point axes") { another_axis }
                #m.add_separator
                #m.add_item("Ruby repeat installer") { youSL_loadRubyRepearter }
                #m.add_item("Explorer") { youSU_explorer }
                #m.add_item("Extensions") { youSU_extSet }
                #m.add_item("Clear clipboard") { another_clearCB }
                #m.add_separator
                m.add_item("Move select") { another_moveSelect }
                #m.add_item("Send select") { another_sendSelect }
                #m.add_item("Send select all") { another_sendSelectAll }
                #m.add_separator
                #m.add_item("Select exit") { another_copyExit }
                m.add_item("Select all exit") { another_copyAllExit }
                #m.add_item("Clear clipboard Exit") { youSU_clearCBExit }
                end #do
                end;# def
                • G Offline
                  glro
                  move select
                  select all exit
                  ok
                  [attachment=0:2vcdagm3]<!-- ia0 -->dj_another_sketchup Ver. 1.2a KISS options.zip<!-- ia0 -->[/attachment:2vcdagm3]
                  Yes, the messagebox has been removed; it is much more convenient, at least for me
                  thank you
                  i'll try to understand what are all the options later
                  • sadyoS Offline
                    sadyo
                    Thanks dukejazz, it's very usefull plugin,
                    btw, I am using dj_another_sketchup Ver. 1.2a KISS options now, but how to make the toolbar appearing again like when I'm using Another Sketchup ver 1.2?
                    I'm no see it in View > Toolbar
                    • dukejazzD Offline
                      dukejazz
                      To turn on toolbars put pound sign in front, like this #=begin and #=end below in this file loader
                      Another Sketchup plus ver 1.2a (toolbar ver)
                      http://forums.sketchucation.com/viewtopic.php?f=323&t=42951
                      • dukejazzD Offline
                        dukejazz
                        update
                        • dukejazzD Offline
                          dukejazz
                          update:
                          7/23/12
                          • Toolbar version
                          • dukejazzD Offline
                            dukejazz
                            Update
                            Dec 26 2012 v1.5.4
                            • G Offline
                              greatoe
                              failed to load on mac.
                              I change "" to "/" in the path, the file loaded, but with this error:
                              Error Loading File Another_Sketchup.rb
                              can't convert Fixnum into String
                              • dukejazzD Offline
                                dukejazz
                                Update to Mac
                                Feb 19, 2012 Another_Sketchup v1.6.2_Mac (no paste in place just paste)
                                Sorry I don't own a mac
                                Not all api codes run on the mac.
                                cmd=Sketchup.send_action 21939;#mac 57637 is one of them (Pc paste in place, Mac paste)
                                If this dose not fix it, I need to know the line #no of the error please.
                                I have releaed the new version at the above downloads (Another_Sketchup)
                                  dtrarch
                                  DJ
                                  Really good of you to share all of this and free too. 👍 👍
                                  Thanks 😄
                                  dtr
                                  • G Offline
                                    greatoe
                                    Thank you dukejazz for the reply.
                                    With the new version still no luck.
                                    The plug-in is loaded, the toolbar is shown, and the menu is added, but after that an error box pop up (see attachment).
