    [Plugin] Another Sketchup v1.6.1 Feb 19 2013
    16 Posts 6 Posters 20.9k Views 6 Watching
      glro
      This plugin is helpful, but it took me time to understand how to use it
      too many options for me ... and "Another sketchup plus" is even more complicated
      KISS... ("keep it simple, sir" approach)
      I basically need only 2 options:
      move select
      select all exit
      and this is how i proceed in detail:
      select the detail i want to modify in the first sketchup session window
      right click, "another sketchup > move select"
      the selection disappears from the first sketchup window and a second sketchup session is opened with the selection in it.
      modify the detail as needed; when it is done:
      right click anywhere in the second sketchup session, "another sketchup > select all exit"
      message asks if i want to save modifications (no...)
      i come back to the first sketchup session
      and this is the important step: go the "menu > edition > paste on place (or something similar)"
      the detail appears in its previous position, and with the modifications
      If these options are all that i need, i guess it will be the same for some other sketchup users...
      The only detail that disturbs me is the messagebox when a sketchup session is opened; would there be a way to get rid of it?
      • dukejazzD Offline
        dukejazz
        move select
        select all exit
        ok
        Here your ver of Another Sketchup Ver. 1.2a KISS options:
        dj_another_sketchup Ver. 1.2a KISS options.zip
        I guess it will be the same for some other sketchup users...
        If you need more options
        Edit another_sketchup Ver. 1.2a KISS
        Plugins\dj_another_sketchup\Another_Sketchup_Plus_loader.rb
        def youSU_contextAa
        UI.add_context_menu_handler do |context|
        m = context.add_submenu("Another Sketchup plus")
        m.add_item("Place in place") { youSCF_placer }
        m.add_item("Replace what is selected") { another_place }
        #m.add_item("Duplicater") { another_sumPaste }
        #m.add_item("Duplicate all") { another_copyAllPaste }
        #m.add_item("Point axes") { another_axis }
        #m.add_separator
        #m.add_item("Ruby repeat installer") { youSL_loadRubyRepearter }
        #m.add_item("Explorer") { youSU_explorer }
        #m.add_item("Extensions") { youSU_extSet }
        #m.add_item("Clear clipboard") { another_clearCB }
        #m.add_separator
        m.add_item("Move select") { another_moveSelect }
        #m.add_item("Send select") { another_sendSelect }
        #m.add_item("Send select all") { another_sendSelectAll }
        #m.add_separator
        #m.add_item("Select exit") { another_copyExit }
        m.add_item("Select all exit") { another_copyAllExit }
        #m.add_item("Clear clipboard Exit") { youSU_clearCBExit }
        end #do
        end;# def
          glro
          move select
          select all exit
          ok
          [attachment=0:2vcdagm3]<!-- ia0 -->dj_another_sketchup Ver. 1.2a KISS options.zip<!-- ia0 -->[/attachment:2vcdagm3]
          Yes, the messagebox has been removed; it is much more convenient, at least for me
          thank you
          i'll try to understand what are all the options later
          • sadyoS Offline
            sadyo
            Thanks dukejazz, it's very usefull plugin,
            btw, I am using dj_another_sketchup Ver. 1.2a KISS options now, but how to make the toolbar appearing again like when I'm using Another Sketchup ver 1.2?
            I'm no see it in View > Toolbar
            • dukejazzD Offline
              dukejazz
              To turn on toolbars put pound sign in front, like this #=begin and #=end below in this file loader
              Another Sketchup plus ver 1.2a (toolbar ver)
              http://forums.sketchucation.com/viewtopic.php?f=323&t=42951
              • dukejazzD Offline
                dukejazz
                update
                Another_Sketchup Ver. 1.3
                fix messagebox hand shake problem has been removed
                rename some features to a better fitting names
                full functions context_menu
                uses the plus sys engin
                • dukejazzD Offline
                  dukejazz
                  update:
                  7/23/12
                  • Toolbar version
                  • move to dj_Plugins folder
                  • dukejazzD Offline
                    dukejazz
                    Update
                    Dec 26 2012 v1.5.4
                    • plugins wrap in Module DJ::pluginsName.methodDJ(name space)
                    • @variable format (name space) dj_variable
                    • plugins name are in subject and name order (easy to look up)
                    • feature toolbar add
                    • Big new programs is safe to use, now in module format
                      greatoe
                      failed to load on mac.
                      I change "" to "/" in the path, the file loaded, but with this error:
                      Error Loading File Another_Sketchup.rb
                      can't convert Fixnum into String
                      • dukejazzD Offline
                        dukejazz
                        Update to Mac
                        Feb 19, 2012 Another_Sketchup v1.6.2_Mac (no paste in place just paste)
                        Sorry I don't own a mac
                        Not all api codes run on the mac.
                        cmd=Sketchup.send_action 21939;#mac 57637 is one of them (Pc paste in place, Mac paste)
                        If this dose not fix it, I need to know the line #no of the error please.
                        I have releaed the new version at the above downloads (Another_Sketchup)
                          dtrarch
                          DJ
                          Really good of you to share all of this and free too. 👍 👍
                          Thanks 😄
                          dtr
                            greatoe
                            Thank you dukejazz for the reply.
                            With the new version still no luck.
                            The plug-in is loaded, the toolbar is shown, and the menu is added, but after that an error box pop up (see attachment).
