    Changing units format via ruby
    5 Posts 2 Posters 2.6k Views 2 Watching
    • jeff hammondJ Offline
      jeff hammond
      is there a way to change the unit format via ruby?
      [say i'm set to architectural -> feet but i want to switch it to decimal -> inches]
      and while i'm at it, how about a way to switch the precision as well?
      thanks
      dotdotdot
        Yes there is - you can control both those and the 'snapping' to.
        There's a tool to swap units - Toggle-Units...
        http://forums.sketchucation.com/viewtopic.php?p=81391#p81391
          jeff hammond
          oh right, i have that plugin.
          basically though, what i'm wondering, is if there is something i can type into the ruby console to do this..
          (apparently there is since that plugin was made but it would take me 3 days to dissect the code and figure out what to type into the console 😳 πŸ˜† )
          i've looked through the api documentation but apparently i missed the part dealing with units.
          thanks
          dotdotdot
            The units part of the API is well hidden away!
            Here's a 'mm' version BUT you can see how to do in 'inches' one...
            ` Sketchup.active_model.options["UnitsOptions"]["LengthUnit"]=2
            mm`
            OR use 0=inch, 1=feet etc...
            ` Sketchup.active_model.options["UnitsOptions"]["LengthSnapEnabled"]=true
            grid snap on
            Sketchup.active_model.options["UnitsOptions"]["LengthSnapLength"]=10.mm
            or whatever
            Sketchup.active_model.options["UnitsOptions"]["LengthPrecision"]=1
            1.5mm not 2mm or 2.01mm
            Sketchup.active_model.options["UnitsOptions"]["SuppressUnitsDisplay"]=true
            don't show 'mm' etc
            Sketchup.active_model.options["UnitsOptions"]["LengthFormat"]=0
            Decimal`
            OR use =3 for fractional, =2 for Engineering, =1 for Architectural...
              jeff hammond
              sweet!
              exactly what i was looking for.
              thank you sir
              dotdotdot
