    [Plugin] Face2Face - autoextrusion between faces
    6 Posts 6 Posters 17.2k Views 7 Watching
    • B
      brian_concannon
      Example resultsSketchup Face2Face Tool
      Here is a Sketchup plugin that starts from just two arbitrary faces. It generates the smooth continuous central path and adds the outside surfaces between the selected faces.
      1 - Select any two faces at any orientations.
      2 - Use menu selections Plugins, then Face2Face Extrusion.
      3 - The plugin then generates the path, and the surface that fits between the faces.
      The result is an blended extrusion with the shape of one of the faces.
      user guide pdf
      The plugin
      • mitcorbM
        mitcorb
        Can the faces have any random orientation, or should they be "on axis" x and/or, y and/or, z? Suggestion,that your subject heading contain [Plugin], so that Jim's plugin hunter will pick it up to place it in the Plugins Index.
        • L
          lexmonteiro
          Thanks!
          It is a very usefull plugin!!!
          • R
            RichardCherry
            This tool is awesome 😄
            It works superbly. The only thing I encountered was that the two faces must be facing in opposite directions for the plugin to work (at least for me).
            It makes things so much easier for me.
            Thank you.
            • L
              leminilab
              Automatic wiring of electrical devices!
              Many people will LOVE this one!
              Thank you very much! 👍 👍
              • "Live every day as if it were your last and then some day you'll be right."
              • "ThomThom rules!!!"
              • P
                Plex
                Thank you for this one. Very useful.
                Sig 👍
