    [Plugin] FredoTools - v4.6a - 21 Oct 26
    464 Posts 123 Posters 843.5k Views 121 Watching
    • T
      tolson68
      TIG, The __loader.rb does exist in the .../FREDOTOOLS_Dir_12/ folder and has it's permissions set to -rw-r--r-- and all other *.rb files have the same permissions.
      Fredo, The __loader.rb file does contain the line:
      Traductor::Plugin.myplugin('FredoTools').effective_load
      ...and nothing else.
      If I rename the 000_AdditionalPluginFolders.rb file the error appears to go away, which seems like an acceptable workaround. I am unable to use WebDialog for that add-on for somereason. All other WebDialogs are working, but that one just displays raw HTML, but does not generate any exceptions other than when FredoTools is loaded, curious.
      Thanks,
      Tom
      • T
        tolson68
        Fredo,
        I stand corrected renaming the 000_AdditionalPluginsFolder.rb did not resolve the problem, but it did expose a different/extended message:
        Error Loading File C:/Program Files/SketchUp/SketchUp 2013/Plugins/FREDOTOOLS_Dir_12/__loader.rb
        can't convert nil into String
        Error Loading File ZLoader__GhostComp.rb
        • S
          songkran77
          πŸ‘ πŸ‘ thank you very much
          • D
            dedmin
            (screencast.com)
            • fredo6F
              fredo6
              @dedmin said:
              (screencast.com)
              Very strange.
              Can come from 2 possible causes:
              1. MaxwellFire modifies the SU model and the texturing (does it?), and then ThruPaint or MaxWellFire script crashes when it is used (could be related to observers)
              2. or there is a more traditional plugin conflict
              Could you send me a model where you do the rendering, but just before you try to apply the TrhruPaint texturing.
              Fredo
              • D
                dedmin
                There is no model - just a simple rectangle, then push-pull to a 3D box.
                • fredo6F
                  fredo6
                  That was just in case MaxwellFire modifies the texture. So just the model after you do the rendering.
                  Otherwise, this may simply come from a plugin conflict, either at code level, or due to handling of observers in MaxwellFire.
                  Fredo
                  • D
                    dedmin
                    The material was just default sketchup material. This file was rendered with Maxwell:
                    Buro_11.skp
                    • fredo6F
                      fredo6
                      [attachment=0:2047gaia]<!-- ia0 -->Buro_11.skp<!-- ia0 -->[/attachment:2047gaia]
                      I get NO crash when using ThurPaint.
                      So it must be another conflict between scripts (There was one for Vray Beta 1.6).
                      Maybe some other users have found a similar problem.
                      fredo
                      • B
                        Bimbalas
                        @tolson68 said:
                        Fredo,
                        I have installed Sketchup 2013 Make on a Linux instance and it seems to be working well. Unfortunately I have a problem loading FredoTools 1.2a. The error message I receive is:
                        I have tried disabling my other plugins to isolate the cause and then adding them back one at a time and when FredoTools is enabled I start having this problem. I'm happy to assist you in any tracing, since I'm aware that SketchUp itself is not supported on Linux. This is a brand new install and all plugins packages have been downloaded within the past 24 hours.
                        I am also encountering the same problem in Sketchup 8 on the same machine.
                        Kind Regards,
                        Tom
                        Hi, Tom,
                        I have the same problem on my nature windows machine and on linux/ubuntu machine through wine. The workaround is very simple. I moved all Fredo6 plugins to default sketchup plugins folder and now all they works as expected. Probably problem occurs on AdditionalPluginFolders.rb level.
                        • T
                          txusic
                          Hi fredo.. IΒ΄ms sure you and all around are bored of answering the same questions.. but i read thoroughly and couldn't find an answer....
                          I work on an old PowerPc G5 (pre-Intel) and SketchUp 7 (7.1.6859)
                          i copy the plugins in the right place
                          mac hd >library > application support > google sketchup 7 > sketchip > plugins
                          tryed to change names, place them in original folders, change the web browser (downloader as safari was giving funny names), change the un-compressor.. every thing to no luck
                          Here is an image where u see shaded all the info
                          thanx for any help in advance...
                          PD congratulations other plugins i tryed, are fantastic!!
                          error file image
                          • chonC
                            chon
                            Fredo,
                            I've got an issue using FredoTools with AdditionalPluginFolders.
                            The problem is related here with shortcuts for illustration.
                            Many thanks to look at that ! πŸ‘
                            SU2019 pro 19.3.253 + VRay 4.00.02 (Next) on Win10-64Bits
                            • fredo6F
                              fredo6
                              @chon said:
                              Fredo,
                              It seems the issue is in LibFredo6 actually (error in the logging of errors!!). I don't know why you have FredoTools in error. Possibly you may open the Windows > LibFredo6 Settings > View Trace Files... dialog box and check if there is more info (in red).
                              Anyway, I would suggest the following
                              • Upgrade to AdditionalPluginFolders 4.2a
                              • Upgrade to LibFredo6 5.3g (just published).
                              Then, if you still get the error, could try to drop and replace the attached file Fredo6_!LibFredo6.rb in the directory where you installed my scripts.
                              Fredo
                              • chonC
                                chon
                                Thanks for help Fredo ! πŸ‘
                                Here is the "View trace files" :
                                As you can see, my Fredo6 tools are up to date... πŸ˜‰
                                Another question : Fredo6 has created a default parameters folder on the first level of C:/ (visible on the 4th line of the "View trace files").
                                Is it possible to locate this folder at another place ?
                                • chonC
                                  chon
                                  Fredo,
                                  update of Libfredo6 solved part of the problem but not all :
                                  Here is the message error :
                                  Here is the trace log (only error items) :
                                  >>>> 1383119187.795;Lib6Core.rb;649;  in `load_full_rubies'
                                  ?FredoTools 1.2a; ERROR in Loading ruby file FredoTools__ThruPaint.rb
                                  undefined method `register_plug' for FredoTools;Module -  //X/SketchUp/Plugins_Communs/FREDOTOOLS_Dir_12/FredoTools__ThruPaint.rb;34
                                  >>>> 1383119187.824;Lib6Core.rb;649;  in `load_full_rubies'
                                  ?FredoTools 1.2a; ERROR in Loading ruby file FredoTools__RemoveLonelyVertices.rb
                                  undefined method `register_plug' for FredoTools;Module -  //X/SketchUp/Plugins_Communs/FREDOTOOLS_Dir_12/FredoTools__RemoveLonelyVertices.rb;36
                                  >>>> 1383119187.853;Lib6Core.rb;649;  in `load_full_rubies'
                                  ?FredoTools 1.2a; ERROR in Loading ruby file FredoTools__MarkVertices.rb
                                  undefined method `register_plug' for FredoTools;Module -  //X/SketchUp/Plugins_Communs/FREDOTOOLS_Dir_12/FredoTools__MarkVertices.rb;36
                                  >>>> 1383119187.877;Lib6Core.rb;649;  in `load_full_rubies'
                                  ?FredoTools 1.2a; ERROR in Loading ruby file FredoTools__CountFacesBySides.rb
                                  undefined method `register_plug' for FredoTools;Module -  //X/SketchUp/Plugins_Communs/FREDOTOOLS_Dir_12/FredoTools__CountFacesBySides.rb;34
                                  >>>> 1383119187.892;Lib6Core.rb;649;  in `load_full_rubies'
                                  ?FredoTools 1.2a; ERROR in Loading ruby file FredoTools__ReverseOrientFaces.rb
                                  undefined method `register_plug' for FredoTools;Module -  //X/SketchUp/Plugins_Communs/FREDOTOOLS_Dir_12/FredoTools__ReverseOrientFaces.rb;34
                                  >>>> 1383119187.942;Lib6Core.rb;649;  in `load_full_rubies'
                                  ?FredoTools 1.2a; ERROR in Loading ruby file FredoTools__ReportLabelArea.rb
                                  undefined method `register_plug' for FredoTools;Module -  //X/SketchUp/Plugins_Communs/FREDOTOOLS_Dir_12/FredoTools__ReportLabelArea.rb;34
                                  ConstructFaceNormal, CurviShear and RevertCurve seem to work fine ! πŸ‘
                                  • fredo6F
                                    fredo6
                                    Very very strange.
                                    I would expect that none works or all work.
                                    I'll have a closer look
                                    Could you show me the content of the subfolder FREDOTOOLS_Dir_12 (files and dates)
                                    Fredo
                                    • chonC
                                      chon
                                      • LAGRARI2012L
                                        LAGRARI2012
                                        very good contribution πŸ‘ πŸ‘ πŸ‘
                                        • fredo6F
                                          fredo6
                                          NEW RELEASE: FredoTools v1.4a - 30 Oct 13
                                          This update implements new naming conventions, fixes a few bugs for future compatibility.
                                          See main post of this thread for download of FredoTools.
                                          Fredo
                                          • P
                                            parsleybrain
                                            Some of my Fredo plugins need an update now. I've never done this before, so my question is how to update those plugins? Do I uninstall the older versions first and download the newer ones or just download the new version and the plugins are updated automatically in this way? Thanks for any help.
                                            • 6
                                            • 7
                                            • 8
                                            • 23
                                            • 24
                                            • 6 / 24
