    Scale SU drawings in InDesign
    extensions
    3 Posts 3 Posters 920 Views 3 Watching
      steven633
      Hi guys,
      After doing a few Interior Design projects in Layout (im an Interiors student). I am starting to tire a little of Layout's clunkiness. I much prefer the high quality interface of InDesign to create presentations.
      I wonder if there is any way to import a scaled SU drawing into an InDesign Doc, in the same way as as you can import into Layout. I realise that it would not be as straight forward, and I also realise that I couldnt alter the scale afterwards in InDesign as you can with Layout. But I wonder if it is possbible to get an accurate scaled drawing on there? Is it possible to create something in PDF and keep the dimensions??
      Any help appreciated
      Steven
      • peter_shawP Offline
        peter_shaw
        I would also like to know that.
        A (pretty bad) workaround i use is to quickly scale it with LayOut, export it as pdf and then place it in InDesign... if u want to change scale in InDesign later, u have to do the math yourself.. note that there is an option in indesign that always keeps the initial scaling percentage of an imported object visible, (so when u resize smth. to 50%, it shows 50% in the scaling box all the time). kinda helpful
        • AnssiA Offline
          Anssi
          I would also say that exporting to scale to PDF or EPS or printing to PDF would be the easiest way. To create a 'to-scale' raster image is also possible, but it is more complicated, and you will have to go through an image editor:
          • in SU, create a parallel view. Draw an empty frame with known dimensions round your model.
          • export an image to a high resolution. Open the exported image in Photoshop.
          • In Photoshop, crop the image to the frame you drew. If your background is uniform, you can use the Trim command
          • Resize the image to the dimensions your frame should have on paper and to the desired final resolution.
          • Now, if needed, you can crop the image further, when you save it, it will retain its dpi value so that it will get placed to Indesign to the right scale.
          Anssi
