    Curtain Material?
    renderpluginsextensions
    2 Posts 2 Posters 5.3k Views 2 Watching
    • pugz1983P Offline
      pugz1983
      Hi Everybody,
      I can't seem to get the material settings right. In trying to achieve the standard white curtain material with the nice white glow. I think it's somthing with refraction and translucency settings but i'm not sure.
      Can somebody help me in the right way?
      Greetz Twan
      • andybotA Offline
        andybot
        Try the vray two-sided material. There's a tutorial about it too (floating around somewhere)
        Simple steps: 1.make your curtain material - (it should be opaque, but if you want it sheer, you can use translucency and maybe a texture map)
        2. create a vray two-sided material (from the vray materials window - and make sure it's NOT the SKP two sided), set both front and back materials to your curtain material, check the box for force one-sided, and set your color to a light gray)
        3. apply your material to your curtain. (I also apply the original material to an edge to make sure my material doesn't get purged.)
