    Rotating Component so long dim is on red axis
    3 Posts 2 Posters 283 Views 2 Watching
    • K Offline
      ktkoh
      I have code to tell me which axis the max bounds dim is on and now I would like to rotate the component so the largest dim is on the red axis. I need help with the translation statement to make the proper rotation.
      model = Sketchup.active_model
      entities = model.entities
      ss= model.selection
      entity = ss.first
      selection_bb = entity.bounds
      max_dir = "blue axis"
      if selection_bb.height > selection_bb.depth
          max_dir = "green axis"
          if selection_bb.width > selection_bb.height then max_dir = "red axis"  end
      else
          if selection_bb.width > selection_bb.depth then max_dir = "red axis" end
      UI.messagebox("Max Dir = " + max_dir)
      Keith
      • sdmitchS Offline
        sdmitch
        One possibility
          ss= model.selection
          entity = ss.first
        #=== save the current origin and transform back to created position ===
          origin = entity.transformation.origin
          trans=entity.transformation
          entity.transform! trans.inverse
          max_dir = "blue axis";axis=Y_AXIS; # if blue, rotate around green
              max_dir = "green axis";axis=Z_AXIS; # if green, rotate around blue
                max_dir = "red axis" ;axis=nil; # if red, no rotation needed
          elsif selection_bb.width > selection_bb.depth
                max_dir = "red axis";axis=nil; # if red, no rotation needed
        #=== Rotate as needed and move back to current location ===============
          if axis
            tr=Geom;;Transformation.rotation(entity.transformation.origin,axis,90.degrees)
          tr=Geom;;Transformation.translation(origin)
        http://sdmitch.blogspot.com/
        • K Offline
          ktkoh
          Thanks for the code it worked just fine. I had finally found the piece I was missing and this is what I had come up with
          ss= model.selection
          entity = ss.first
          else
          case max_dir
          when "blue axis"
          tr = Geom;;Transformation.rotation [0,0,0], [0,1,0], 90.degrees
          entities.transform_entities tr, entity
          when "green axis"
          tr = Geom;;Transformation.rotation [0,0,0], [0,0,1], 90.degrees
          Similar and the results are both ok.
