Rotating Component so long dim is on red axis
I have code to tell me which axis the max bounds dim is on and now I would like to rotate the component so the largest dim is on the red axis. I need help with the translation statement to make the proper rotation.
model = Sketchup.active_model entities = model.entities ss= model.selection entity = ss.first selection_bb = entity.bounds max_dir = "blue axis" if selection_bb.height > selection_bb.depth max_dir = "green axis" if selection_bb.width > selection_bb.height then max_dir = "red axis" end else if selection_bb.width > selection_bb.depth then max_dir = "red axis" end end UI.messagebox("Max Dir = " + max_dir)Thanks
Keith -
One possibility
model = Sketchup.active_model entities = model.entities ss= model.selection entity = ss.first #=== save the current origin and transform back to created position === origin = entity.transformation.origin trans=entity.transformation entity.transform! trans.inverse #====================================================================== selection_bb = entity.bounds max_dir = "blue axis";axis=Y_AXIS; # if blue, rotate around green if selection_bb.height > selection_bb.depth max_dir = "green axis";axis=Z_AXIS; # if green, rotate around blue if selection_bb.width > selection_bb.height max_dir = "red axis" ;axis=nil; # if red, no rotation needed end elsif selection_bb.width > selection_bb.depth max_dir = "red axis";axis=nil; # if red, no rotation needed end #=== Rotate as needed and move back to current location =============== if axis tr=Geom;;Transformation.rotation(entity.transformation.origin,axis,90.degrees) entity.transform! tr end tr=Geom;;Transformation.translation(origin) entity.transform! tr -
Thanks for the code it worked just fine. I had finally found the piece I was missing and this is what I had come up with
model = Sketchup.active_model entities = model.entities ss= model.selection entity = ss.first selection_bb = entity.bounds max_dir = "blue axis" if selection_bb.height > selection_bb.depth max_dir = "green axis" if selection_bb.width > selection_bb.height then max_dir = "red axis" end else if selection_bb.width > selection_bb.depth then max_dir = "red axis" end end case max_dir when "blue axis" tr = Geom;;Transformation.rotation [0,0,0], [0,1,0], 90.degrees entities.transform_entities tr, entity when "green axis" tr = Geom;;Transformation.rotation [0,0,0], [0,0,1], 90.degrees entities.transform_entities tr, entity endSimilar and the results are both ok.
