    Vector Rendering Layout
    layout
    3 Posts 3 Posters 1.2k Views 3 Watching
    • A
      adamj0112
      I have a detailed complex model I made in SU and have made 3 of the 4 elevations I need (vector rendered in Layout3) but the fourth one (which is the Front View of the model) will not Vector Render in Layout3, no matter what I do. I have cleaned up the model (clean up 3 from TomTom), I have gave the Elevation its on Layout file and page, I have done everything I can think up and it will not work. Mind you I got 3 other Vector Rendered Elev. from Lyout from the same model...Any ideas why this is happening. 😠 HELP!
      Thanx, AJ
        Any chance of posting the LO file? Or send it via a PM? Hard to tell otherwise.
        • D
          dancoast
          I have found when issues like this arise if you delete the affected file, purge in document setup, and then reload it back into layout it may clear that up..... has worked for me in certain situations in the past.
