    Render Problem with Model Imported from Rhino
    extensions
    8 Posts 5 Posters 748 Views 5 Watching
    • K
      Kraw
      Hey Team,
      I'm working on a model which was originally built in Rhino.
      I saved it as an skp using Rhino 5 and the model came in meshed but altogether workable.
      After developing the model further in sketchup, I'm finding that when I render shots using the VRay plug-in, the model renders completely incoherently!
      Is it possible to correct this? or was it simply a conversion issue from Rhino that can't be salvaged? thoughts?
      See, everything looks normal here...
      And this one is incoherent
      • soloS
        solo
        Try exploding it before render.
        http://www.solos-art.com
        • jeff hammondJ
          jeff hammond
          hey wait.. the incoherent version looks better!
          dotdotdot
          • mitcorbM
            mitcorb
            I am unable to see any similarity in the two images. Are these of the same model? And I don't mean edge detail, or textures.
            • S
              sepo
              Is it possible to have peak in .3dm model ? You have obviously used Rhino 5 which is in beta and therefore not 100% reliable.
              • K
                Kraw
                Here's the model. I got the same result after exploding everything.
                I think there's a chance it's related to rhino being a beta version?
                Thanks for the feedback - and, i know, the vray result is way cooler...
                111205 Model 1.skp
                • K
                  Kraw
                  ps I wanted to mention that the views i uploaded were in fact the exact same view!
                  • S
                    sepo
                    I meant to look at rhino .3dm model. Wanted to see if anything is different.
