    How do you make a dome with a rectangle bottom?
    15 Posts 7 Posters 3.2k Views 7 Watching
      cmartin
      I have a student who made a dome for his rectangular shaped stadium with the arc tools, but the faces do not appear, just lines. How do you make a dome with a rectangular bottom?
      • mitcorbM Offline
        mitcorb
        Quick and easy answer would be Curviloft by Fredo6, unless you would rather the student turn this out with native tools. In which case, one would use progressive/ sequential pushpull, scale a face along the rectangular "rail". It would require significant amount of "hand stitching" here and there, if the curved surfaces change.
        • mitcorbM Offline
          mitcorb
          Hi, cmartin:
          Didn't see the pic.
            cmartin
            here's a pic of it
            EDIT:
            sorry....it didn't work. I think it might be too difficult for my student to do it with native tools. I'll try and get that script. thank you.
              cmartin
              ok....i think it should work this time.
              if my students are not that advanced, do you think it would be better to just try and use the script?
                See this thread
                and this tut by Simon Lebon for idea 😉
                • Jean LemireJ Offline
                  Jean Lemire
                  Hi folks.
                  I don't know what type of dome you want so here are some ideas in the attached SU file.
                  Rectangular to dome.skp
                  • jeff hammondJ Offline
                    jeff hammond
                    one of the few times i might recommend the soap skin & bubble plugin.. (the square edges of the roof allow for a nice symmetrical tin to be created)
                    (www.tensile-structures.de)
                    for this one, i just made the skin using the outlining roof edges then inflated to a pressure of 10..
                    i realize the shape is different than those shown in the student files but it may work out for them?
                    click pic -> larger..
                    dotdotdot
                    • charly2008C Offline
                      charly2008
                      another possibility is "Extrude Edges by Loft".
                      Dome.skp
                      • mitcorbM Offline
                        mitcorb
                        Then, again, now seeing the intended curvature it seems that the problem is similar to the Carnival Tent question posted in the last day or two, and maybe FollowMe could do it?
                          jeff hammond
                          if those are just arcs going corner->corner.. midpoint->midpoint.. then the mids of those midpoints etc then no, follow me wouldn't work right..
                          that said, i doubt the student really knows what shape he/she is going for so the follow me technique (as demonstrated by jean itt) would be the simplest way to go about it..
                          i do think once the student see what type of surface their profile lines would create, it would be different than what they were originally imagining.. this thread has a few different versions and it'd be neat if the student tried different variations (at least it's an exercise in helping to get a shape/idea out of your head and into something more tangible)
                          dotdotdot
                            Same than Soap Skin and Bublbe but more versatile Ferrari
                            it's more friendly and better result and free 😉
                            http://forums.sketchucation.com/download/file.php?id=58250
                              Like tensile struture than Soap Skin and Bubble but more versatile Ferrari 😉
                                cmartin
                                thank you so much. I'll try and install all those plugins. And thank you for the models showing me step by step using the follow me tool. You guys are awesome!
                                I'm the only person doing sketchup at my middle school with my students, and you guys have been an awesome resource in helping me out. Thanks again.
                                • dukejazzD Offline
                                  dukejazz
                                  Rectangle and 1/4 circle
                                  Select all Rectangle edges then follow me tool
                                  Use windows_soften edges
