    Creating a straight box base contour around a 3d curved su
    6 Posts 3 Posters 437 Views 3 Watching
      clubber2k
      When creating a topo surface from cad file lines the surface is a thin chip like object.
      I want to give it a real cardboard model feel by closing the area under the surface into a closed box.
      whats the best way to do this? the surface has many edges and I cant make anything intersect with it in a single swipe.
      attached is an image of the surface and a box under it. I want the box walls to fit the surface edge so it doesn't seem floating like it does.
      is there a quick and simple way to do this that I am missing?
      Thanks!
      • gillesG Offline
        gilles
        Projection Tools by Didier Bur, maybe this can help:http://forums.sketchucation.com/viewtopic.php?t=20140#p167471
          clubber2k
          Yup!
          how did I miss this great plugin!
          I had to delete the surface and only use the outline since the plugin made a projection of every small face in it but pretty good.
          • gillesG Offline
            gilles
            If you select only the outer edges and choose the last icon of the toolbar it project edges along a vector.
            • Jean LemireJ Offline
              Jean Lemire
              Hi folks.
              See this SU file for ideas.
              Box under topo.skp
                clubber2k
                @jean lemire said:
                Hi folks.
                Great work!
                That is actually what I was looking for - don't know why I did think of it myself since I'm not a beginner - but I didn't so - Thanks!
                I did find a great plugin on the way anyway πŸ˜„
