    Nite Vision Style
    5 Posts 2 Posters 1.0k Views 2 Watching
    • iichiversiiI Offline
      iichiversii
      Iv being on the look out for a style which resembles the effect of a night vision scope, also where dark colours appear black and light colours appear white, white repressenting heat and black repressenting low temperture, the remainder of the screen would be a bright screen, around the edges of the style having a scope tunnel effect would be great too, is there a style out there like this for SU? Or can someone create it?
      Bring on the Rain...
      • Rich O BrienR Online
        Did you try adjusting the Monochrome screen style under 'assorted styles'?
        Faces can only show one color unless you reverse some faces to give the effect you want. Another option would be to apply this to still images in Post Pro by filter in PS or GIMP.
          iichiversii
          Ah yes, reverse the faces is something i didnt know would work, will give it a try, i would rather do it in SU than in PS, as its a scene im trying to make and not an image, if i get it to work ill post it here laters, thanks again Rich...lol if you had a yoyo for everytime i thanked you, you would be worth millions if not billions, haa
            iichiversii
            This is the best i could do, i had a crosshair on it but it didnt look right so removed it, I challenge someone to do better, its very had to get it just right, Rich your tip worked really great with changing back colours and front colours
              iichiversii
              After all that i never saved the style 🀒
