    Preparing VIew..
    3 Posts 3 Posters 334 Views 3 Watching
    • M
      mandar1983
      Hello,
      I m designing a township in SU, and i need a reference image on the background to adjust my view accordingly. Is this facility available in SU if yes how?? I dont want to create a plane and give a map to it..i want entire background of that image..that should be seen even i change my view.. if someone is using 3ds Max..the same facility is available in that..
      Also I would like to know how to mirror the object ..and does SU have some kind of concept like Xref ?? if yes then how to use it..
      Please Help..
      Thanks..
      • B
        bjornkn
        Background image can be set up using Styles.
        No automatic Xref, but you could use rclick menus for component : Reload.
        • DavidBoulderD
          DavidBoulder
          In addition to right clicking to update a component, you can also save a component to its own sketchup file. You can then have multiple versions of this component and load in the one you want. It also allows multiple people to work on a project at the same time. You can flip a component along its x, y or z axis to accomplish a mirror.
          David Goldwasser
          OpenStudio Developer
