    Proto-typing
    9 Posts 3 Posters 576 Views 3 Watching
    • fuzzionF Offline
      fuzzion
      Lets say I have design. THe Size of 30cm x 30 cm 30cm.
      It is in SKP file.
      I need proto type to test viability of product and patenting the idea.
      I called a local prototype shop in SIngapore and they said they dont do SKP.
      I tried cadspan but still got many triangles not matter what setting. Now stl
      exporter expired. With 3dm the edges arent really subdivided smooth and very triangular.
      SO what can I do ???? 😒
      WHat are the cheapest way to prototypes .skp designs ❓
      "Only the dead have seen the end of war" - Plato
        d12dozr
        I recommend using Shapeways. I've found that they are the cheapest, I believe even for international shipments. Shapeways accept 3D files in Collada format, which you can export from SU free or Pro. Feel free to ask me any other questions you may have about the modeling or ordering process.
        http://goo.gl/f7ooYh
        • fuzzionF Offline
          fuzzion
          I checked them out. Its a dream come true if they can do what they say they can do.
          But should i still use meshlab MeshLab & Netfabb ?? even though i think it looks perfect? Or
          do they have proprietary software that makes .dae files work like magic.
            Simply upload a dae file and check out the results. I have also tested it (though haven't got anything printed by them). Or send a PM to Rich. He has a printer, too. πŸ˜‰
              d12dozr
              You don't need Meshlab or Netfabb unless you are making a multicolor 3D print - then you can use Meshlab to convert the DAE to VRML.
              If you need an STL file, you can export directly from SU using this plugin.
              I've ordered several prints from them - it is like a dream! β˜€ Its very exciting to open the package and see an object you designed for the first time πŸ˜„
              What kind of printer does Rich have?
              • fuzzionF Offline
                fuzzion
                It worked like a charm with the .dae extension from SU I will report back on the quality of build and any other vitiating factors when the time arrives. Aside from that, I must say thay have excellent customer support and their costing is really competetive πŸ‘
                • fuzzionF Offline
                  fuzzion
                  Product recieved quickly and perfectly. They also do some touch ups on your behalf as well for free.
                    d12dozr
                    Awesome. Welcome to the age of digital fabrication!
                    • fuzzionF Offline
                      fuzzion
                      Ty πŸ˜„
