    Extrude Tools Fail to load
    4 Posts 2 Posters 309 Views 2 Watching
    • kenK Offline
      ken
      After installing the latest update on the extrude tools I notice that not all the tools are loading. I don't have a prior version here on the road, so I couldn't try out an older version.
      I have attached two images. One is the screen capture showing the toolbar and the plugin menu selection. You will see that there is only 6 selections. The second image shows the files that are in the plugin directory. All twelve files are there, plus the icons, which I don't show.
      Not sure if this was the case on the update before this update as I hadn't used the tool for some time. So this may have been a problem before this update.
      Thanks in advance
      Ken
      • kenK Offline
        ken
        Oops! Second image.
        • kenK Offline
          ken
          Well, removed all the files from the zip file and re-installed. That did it. Not, sure what happen. Sorry about the confusion.
          Ken
            Maybe a Windoze 'Compatibility Files' issue - check your 'permissions' for the Plugins folder properties ?
