    [REQ] model is loaded alarm
    6 Posts 2 Posters 579 Views 2 Watching
    • halroachH Offline
      halroach
      For those of us who are not always working on the fastest computers out there, sometimes you want to open a relatively large and complex model which can jam sketchup for a couple of minutes. Precious minutes that could be spent on working on another model in a separate window, reading Sketchucation forums, and maybe even catching a couple of minutes of shut-eye.
      Wouldn't it be wonderful if sketchup played an alarm tone/music/single beep/continuous beep/user selected mp3/... the minute the model is loaded? Do you think it's possible to write a script that would know when the model is done loading?
      An Idea...
      FlexTools - Super Quick Windows, Doors, Slats...
        <span class="syntaxdefault">class BigBrotherAppObserver </span><span class="syntaxkeyword"><</span><span class="syntaxdefault"> Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">AppObserver<br />  def onOpenModel</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> model </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">    UI</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">play_sound</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> </span><span class="syntaxstring">"hal9000.wav"</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">  end<br />end<br />Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add_observer</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> BigBrotherAppObserver</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">new </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault"> </span>
        ( Doesn't work if you open a model by double-clicking a file. )
        NotifyModelOpen.zip
        • halroachH Offline
          halroach
          I'm not quite sure how to apply the code.
          Paste the text into an .rb file and substitue the wav file with the one I want? didn't seem to work...
          @thomthom said:
          <span class="syntaxdefault">class BigBrotherAppObserver </span><span class="syntaxkeyword"><</span><span class="syntaxdefault"> Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">AppObserver<br />  def onOpenModel</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> model </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">    UI</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">play_sound</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> </span><span class="syntaxstring">"hal9000.wav"</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">  end<br />end<br /></span>
            whooops. Forgot to attach the observer... 😳 Updated the code
              Also added an zip file with the code in a .rb file and sample audio.
              • halroachH Offline
                halroach
                Works Wonderfully!
                Thanks ThomThom
