    Problem with FredoScale toolbar
    7 Posts 3 Posters 840 Views 3 Watching
    • C
      CalypsoArt
      I had pm-ed Fredo to thank him for his great work and creations and also mentioned this small glitch. He suggested I pot it here.
      I use several of Fredo's creations on a regular basis. However, I've noticed an inconstancy with the FredoScale tool bar on my machine. (I have not noticed it with any others) I know I've seen discussion here about some toolbars not being consistent in SU. I never really had that problem, but I have recently noticed it with FredoScale. Can't say when it started. I'm not sure if this is unique to my machine, and it's not really a major problem. Still, I'd love to know why it happens only in this one tool bar.
      The problem: Often after I restart the program the toolbar switches from 2 columns of icons to 3. See attached images. As I said, it is not a problem per say, just an oddity.
      My machine is home built with these components if that matters.
      Windows 7 Pro 64
      ASUS Rampage Gene III
      Intel i7 930
      ATI FirePro V4800
      12GB Kingston 1600GB PC3-12800 1600MHz 240-Pin DDR3
      Crucial SSD 128gb Drive
      WD 1T drive
      Below are images showing the Toolbar correctly and after a restart.
      • V
        Vicspa
        Have you gone to (view/toolbars/save toolbar positions)
        • fredo6F
          fredo6
          There is an option to remove the separators in the FredoScale toolbar (in the Default Parameters dialog box).
          Maybe this will help to have a more consistent layout when icons are shown in a vertical toolbar.
          Fredo
          • C
            CalypsoArt
            Fredo
            Pardon my ignorance, but where do I find the "default parameters"
            • fredo6F
              fredo6
              Go to the menu Tools > Fredo6 Collection > FredoScale > Default Parameters....
              Th option should be toward the end of the list shown in the dialog box
              Fredo
              • C
                CalypsoArt
                Fredo
                Found it. I was unaware of the possible preference set up. Thanks.
                • C
                  CalypsoArt
                  Nope. Still having this problem. Maybe it's a glitch in my vcard driver or something. Just odd that it is not apparent with any other tool bar.
