    How can i get rid of these bits?
    3 Posts 3 Posters 314 Views 3 Watching
    • C
      cjrwil
      Im trying to export a 2d model of this terrain with this dam on top. however, parts of the terrain underneath are showing through through the dam model where the 2 surfaces get close to each other.
      any ideas of how i can get rid of these/ stop them from showing?
      Chris
      notice the grey slivers of terrain showing through the white dam model
      • mitcorbM
        mitcorb
        Make sure that the dam fully intersects the terrain. Select the portions of the model where the dam touches the terrain. Right click , intersect selected. Wait. Then navigate below and remove surfaces and edges that will not be seen, or that logically would not exist if this were real. Does this help?
        • W
          wyatt
          Also try turning on hidden geometry (View>Hidden Geometry). That will allow you to edit/delete portions of the terrain mesh that shouldn't be there.
