    Keyboard Shortcuts Stop Working
    2 Posts 2 Posters 7.9k Views 2 Watching
    • gtalaricoG Offline
      gtalarico
      I just reported this at the official SU Bug report, I thought I would post it here as well.
      This has happened with me for a while, but today I decided had enough... : )
      I am not able to reproduce it, but it happens once or twice a week...
      All keyboard shortcuts stop working. Tools still work if I use menu or icons, but all keyboard shortcut are not responsive.
      (Yes, the windows is on focus: side note, this is another things that it is really annoying: SU window looses focus...)
      This happens at my computer at work, and at home.
      Usually while working on heavy models.
      Restarting SU fixes it.
      Am I alone here? 😲
      -Gui
      http://www.gtalarico.com
      • dukejazzD Offline
        dukejazz
        Look like a over loaded gray out condition of use of memory, alot of features disapper when memory hits limits
        Make two copy skeckup 8 one with no plugins (in plugin folder) for the layout, and the other (with plugins) for editing objects. (to layout)
        Start the object sketchup first,
        Then open layout sketchup.
        Do your work:
        When done close layout sketchup first,
        Then close object sketchup last
        also
        A Fix for some startup Sketchup splats:
        Clean out the reg of google sketchup 8 toolbars useing registry editor and wordpad then open only the plugins you need.
        You may had a 1000 listed witch loads to ram memory evey time it loads often cause sketchup to splat.
        (hint) keep a copy of of google sketchup 8 reg save to fix problems later
