    Panelling plug in?
    16 Posts 8 Posters 1.5k Views 8 Watching
      Scostumatu
      Is there a plug in that could help me with alucobond style panelling? Soemthing that can also do tiles?
      see pics below.
      S
        Components onto face by Chris Fullmer for plane surfaces ?
        Shape Bender for round Surfaces by Chris Fullmer again? ๐Ÿ˜‰
        • soloS Offline
          solo
          IMO vanilla SU can do that pretty well. line, offset and pushpull.
          JPP, TOS and Zorro for rounded bits.
          http://www.solos-art.com
            Scostumatu
            Thanks for the reply.
            However what is vanilla SU? Im a little lost here ๐Ÿ˜•
            JPP, TOS and Zorro are they plug ins?
            thanks again
            • soloS Offline
              solo
              Vanilla - Standard SU tools.
              JPP - Joint push pull
              TOS - Tools on surface
              Zorro - Zorro/ cutting
                Scostumatu
                thanks - now im with you.... it does do a great job of it, its just time consuming.... it would be great if it could subdivide a big plane into tiles and extrude them a little like tiles....
                Thanks anyways guys... appreciated...
                • srxS Offline
                  srx
                  Try Protrude plugin.
                  www.saurus.rs
                    Slicer or Lattice Maker by TIG is for you ๐Ÿ˜„
                      bjornkn
                      Another alternative, using "vanilla SU", is to make a few components - one for each size of panel.
                      Very fast, easy and flexible.
                      • jolranJ Offline
                        jolran
                        Heres my go at it. Minitut. Was made in a hurry so don't mind misspelling.
                        Time is swift!
                        Oh yeah and it's only for non surfaces..
                        • jolranJ Offline
                          jolran
                          There is a didicated plug for that but don't remember its name!
                          Really??? ๐Ÿ˜ฎ
                          Oh snap. Time wasted..
                            Seems there is a didicated plug for that but don't remember its name and the author! ๐Ÿ˜ณ
                            • CadFatherC Offline
                              CadFather
                              windowiser?
                                Refound what that I had not remember! โ˜€
                                Maybe not exactly that you want but take a look! ๐Ÿค“
                                This was a request for a plugin to automatically divide up a solid into individual solids.
                                Group PushPull 2D Faces by Kyyu
                                • jeff hammondJ Offline
                                  jeff hammond
                                  no, not really.. as seen in the above responses, you're going to have to do it manually or use some plugins that might get you half way there ๐Ÿ˜‰
                                  You could approach this a thousand different ways.. bjornkn's suggestion of components is a good one depending on the complexity and/or number of unique sized/shaped panels..
                                  my approach (at the moment ๐Ÿ˜„ ) would be something like this:
                                  (using solids)
                                  [sorry, 10+ minutes long.. even after i edited out the parts when waiting for sketchup to process]
                                  [flash=853,480:1y0qamf9]http://www.youtube.com/v/HO1Qdd-SiGM?version=3&hl=en_US&rel=0[/flash:1y0qamf9]
                                  dotdotdot
                                    Scostumatu
                                    (using solids)
                                    [flash=853,480:2e3b2nwv]http://www.youtube.com/v/HO1Qdd-SiGM?version=3&hl=en_US&rel=0[/flash:2e3b2nwv]
                                    Dude! WOW thanks so much for creating a VID... really really appreciated! Thanks bro!!
