    Way to make grooves or reveals?
    32 Posts 12 Posters 10.6k Views 12 Watching
      cuttingedge
      I worked on joinery company and most of the time offset or copying lines can outline the groove. and do a joint-push pull all at the same time.
      Once one groove is outlined, copy or array to as many as required. quick select by doing a crossing in parallel front or side view. then joint push-pull to give it a uniform recess.
      this works with curved faces as well.
        rv1974
        Seems multiface-offset by Remus + inverse selection by Tig
        • Joint PushPull by fredo 6 can make some tricks in 3 clicks 😉
        http://forums.sketchucation.com/download/file.php?id=87095
        Windowizer would do it with one OK click (bonus: material separation)
          jmqrsq
          Has this been solved with a plugin yet? If so could someone kindly point me to the download? Thank you!
          • pbacotP Offline
            If you look back in the thread a few ideas were discussed. Profile builder for one. There's not a one-shot solution, I don't think. What I was imagining was more of line(s) on surface(s) , select,run ruby, default setting box (depth and width), OK, and --boom --grooves in surface(s), no cleanup or other steps to do.
              rv1974
              IMO The lack of efficient rock solid groove maker is one of the narrowest bottle necks (in SU-ArchViz field). I requested it over 9000 times here and there but no luck. Would gladly buy it for sure.
              • srxS Offline
                srx
                Maybe the Inverse of Lattice Maker http://sketchucation.com/forums/viewtopic.php?p=244981#p244981
                ...and with boolean tools you make groovs 😄
                www.saurus.rs
                • srxS Offline
                  srx
                  And there is also Bevel Maker https://youtu.be/ye4mcp0TPy8
                  www.saurus.rs
                    rv1974
                    None of mentioned above work with preselected edges (THE only edges I want to be grooved).
                    The only combo that more or less 'holds the water' is S4U Frame Maker+ Booltools 2,
                    but still, there's a lot of space for improvement.
                      Maybe this can help you...
                      Sdmitch has made an X,Y "Inflator" component(s)
                      Ask him!
                        rv1974
                        How does this relate to groove making?
                          About the first post #1
                          If you copy the original component, launch the plug Inflator, Copy in Place then explode...
                          Seems you must have the result asked ?
                            txhoyt
                            Do you have any idea where to find this plugin!?
                            • 2 / 2
