    Way to make grooves or reveals?
    32 Posts 12 Posters 13.4k Views 12 Watching
      rv1974
      Seems multiface-offset by Remus + inverse selection by Tig
      • Joint PushPull by fredo 6 can make some tricks in 3 clicks 😉
      http://forums.sketchucation.com/download/file.php?id=87095
      Windowizer would do it with one OK click (bonus: material separation)
        jmqrsq
        Has this been solved with a plugin yet? If so could someone kindly point me to the download? Thank you!
        • pbacotP
          If you look back in the thread a few ideas were discussed. Profile builder for one. There's not a one-shot solution, I don't think. What I was imagining was more of line(s) on surface(s) , select,run ruby, default setting box (depth and width), OK, and --boom --grooves in surface(s), no cleanup or other steps to do.
            rv1974
            IMO The lack of efficient rock solid groove maker is one of the narrowest bottle necks (in SU-ArchViz field). I requested it over 9000 times here and there but no luck. Would gladly buy it for sure.
            • srxS
              srx
              Maybe the Inverse of Lattice Maker http://sketchucation.com/forums/viewtopic.php?p=244981#p244981
              ...and with boolean tools you make groovs 😄
              www.saurus.rs
              • srxS
                srx
                And there is also Bevel Maker https://youtu.be/ye4mcp0TPy8
                www.saurus.rs
                  rv1974
                  None of mentioned above work with preselected edges (THE only edges I want to be grooved).
                  The only combo that more or less 'holds the water' is S4U Frame Maker+ Booltools 2,
                  but still, there's a lot of space for improvement.
                    Maybe this can help you...
                    Sdmitch has made an X,Y "Inflator" component(s)
                    Ask him!
                      rv1974
                      How does this relate to groove making?
                        About the first post #1
                        If you copy the original component, launch the plug Inflator, Copy in Place then explode...
                        Seems you must have the result asked ?
                        • T
                          txhoyt
                          Do you have any idea where to find this plugin!?
                          • 2 / 2
