    Convert Sketchup drawing to .dwg or .dxf
    5 Posts 2 Posters 4.6k Views 2 Watching
    • G
      Gumleguf
      Hello,
      Please help me understand if what I'm planning can actually be done.
      I need to have some plates CNC'ed from say a 2mm titanium -or carbon fiber plate. If I draw the shape of the plates in Sketchup (not the Pro version) can I then have someone convert it in Sketchup Pro to .dwg or .dxf files that can then be imported into AutoCad?
      /Greg
      • GaieusG
        You can certainly can have someone convert it for you - as well as you may be interested in this plugin:
        http://forums.sketchucation.com/viewtopic.php?t=40773
        • G
          Gumleguf
          Sweet. Thanks. I'll give it a shot and get back with questions. πŸ˜„
          • GaieusG
            If you have questions regarding the plugin, ask in that topic instead. Since I have the pro version (with native dwg/dxf export/import), I do not need and have/use that plugin.
            πŸ˜‰
            • G
              Gumleguf
              Of course. πŸ˜‰
