    How to add specularity map in Vray materials option ?
    renderpluginsextensions
    26 Posts 6 Posters 53.5k Views 6 Watching
    • andybotA Offline
      andybot
      @john2 said:
      what does 1.55 in Fresnel mean? ❓
      The Fresnel value is for the IOR (Index of refraction) - it's the cosine of something or other... see if you can decipher the wikipedia article
      • john2J Offline
        john2
        yup i know about index of refraction since a long time [thanks to all my class 9 physics lectures πŸ˜† ] you really gave me a deja vu πŸ˜„
        i'm talking about Reflection.
        Im aware that IOrefraction is
        sine of angle of incidence in air
        divided by
        sine of angle of refraction in the material
        • andybotA Offline
          andybot
          similar principal applies - the ior sets the strength of the reflection based on the angle of incidence.
          • john2J Offline
            john2
            uhhuh...can't figure this. the angle of light changes when it travels from one medium to another, that's why the bending occurs. but according to the law of reflection. angle of incidence is equal to angle of reflection.
            • ATLAStudioA Offline
              ATLAStudio
              Thanks Stefan for your tips on map slots, been very useful! I managed to cook this up following your advice and Bertrand Benoit's 'materialism' post.
              To clarify on the percentage contribution of the glossiness, I've found that once you plug a map into the glossiness slot this overrides whatever figure you use. In the example below is the same material with spec map and glossiness set to 1.0, 0.8 and 0.2 from L to R, it's not a great example scene but you can't see any diminished reflection as a result of the map being 'darkened'. If you drop the texture multiplier however, it blurs the whole thing rather than reducing the contribution of the map alone (shiny cube example), which means you have to go into photo editing software to finetune the map. This is a bit frustrating, if anyone knows a workaround within vray settings please share!
              http://www.atlas-studio.co.uk
              • andybotA Offline
                andybot
                did you make sure the specular map is in the perpendicular slot of your fresnel reflection options? If it is in that location, then glossiness will be affected.
                • 2 / 2
