    FREE Maxwell Render for Sketchup (free version).
    extensions
    256 Posts 43 Posters 121.9k Views 43 Watching
    • pbacotP Offline
      Thanks Jason! That's interesting and good to hear. Peter
      • utilerU Offline
        utiler
        Am I right in saying that Maxwell doesn't recognize section cuts and hence won't render floor plans?
        Just Curious...
        • jason_marantoJ Offline
          jason_maranto
          Maxwell does not currently recognize section cuts (because they are not real geometry) -- Maxwell has something similar called Z-Clipping, which can be used for floor plans... however it's worth noting that Maxwell also has some issues with non-perspective based camera views. So a true floor plan would be tricky (though if you are willing to accept a slight fudge factor it can be done).
          Best,
          Jason.
          • utilerU Offline
            utiler
            Thanks Jason,
            Are you talking about the full Maxwell Suite or Maxwell for SketchUp?
            As for non perspective based views I guess I could wind out the FOV to near 0 and render..? πŸ‘
            Just Curious...
              jason_maranto
              Both. Maxwell cameras always operate in 3-point perspective, so orthographic and 2-point perspectives are "approximate" matches... which is often close enough. The plugin should automatically make the adjustments for you.
              To be clear about what I said before: you can setup section cuts using SketchUp, but you would have to "bake" them into the geometry, either manually or via a plugin.
              Best,
              Jason.
              • utilerU Offline
                utiler
                Thanks Jason, you're da Maxwell Man!!!!!
                Just Curious...
                • peterboodtsP Offline
                  peterboodts
                  Small (dumb?) question.
                  When I add a picture to an object in sketchup and render using Maxwell for Sketchup then the image doesn't render.
                  Do I do something wrong ? or do I need to set some settings to make it work ?
                  Peter
                    jason_maranto
                    Could you clarify exactly how you are adding the picture?
                    Best,
                    Jason.
                    • utilerU Offline
                      utiler
                      Hi Jason, Is there a way to view the mxm files from the Insert dialog box? [See attached screenshot]
                      Would be nice to know what the materials look like rather than relying in names...
                      πŸ‘
                      Just Curious...
                        jason_maranto
                        The full render suite installs a thumbnail viewer so that you can view the material previews like you would any other program thumbnail... however I'm pretty sure the stand-alone plugin does not have this due to the lack of MXED.
                        I really feel like the lack of MXED is crippling to the stand alone version and I hope this is resolved somehow in future updates... as a user of the stand alone plugin my number one request would be to either improve the material editing controls in the plugin itself or include MXED in the package and I would make those requests directly here:
                        301 Moved Permanently
                        (www.maxwellrender.com)
                        If enough users make the request I'm sure something would happen.
                        Best,
                        Jason.
                        • utilerU Offline
                          utiler
                          Thanks mate, I will! πŸ‘
                          Another thing: attached is a screenshot of a render in progress. You'll see a png of a Fig tree in the model which I have wound back the opacity for clarity behind but when rendered the image almost doesn't show. Am I better off changing the opacity in the image itself prior to importing it in as a component?
                          πŸ‘
                          Just Curious...
                            jason_maranto
                            Yeah definitely, the way the plugin interprets SketchUp material Opacity is not good for this type of stuff -- partially because it always makes it shiny (to mimic glass).
                            Best,
                            Jason.
                            • utilerU Offline
                              utiler
                              ok, cheers. πŸ‘
                              Just Curious...
                              • G Offline
                                garystan
                                Jason_moranto :
                                             Apparently, Maxwell for Sketchup has been removed.  I tried your link, and I get an  "Ooops......" error page.   I tried looking for it and, again, it has been removed from the internet.
                                                          garystan
                                • tuna1957T Offline
                                  tuna1957
                                  garystan , get maxwell here...http://www.nextlimit.com . They have a 30 day demo version and the paid version.....
                                    Better to use easy free Real Time render like SimLab Composer Lite (max 1920 * 1080)
                                    http://www.simlab-soft.com/Simlabimages/Simlab_Composer/technologies/Features_images/Features_page/FreeFinal-min.jpg
                                    • 9
                                    • 10
                                    • 11
                                    • 12
                                    • 13
                                    • 13 / 13
