π Easy Offset | Offset selected faces in SketchUp in positive and negative offsets. Download
Overridden FOV
My field of view is not the same in sketchup as in the vray renderings. Why can that be? I haven't checked the override FOV.
Hi edn,
Try this plugin:
http://forums.sketchucation.com/viewtopic.php?t=15491(And we have a special V-ray subforum under the extensions forum - I am moving your topic there)
OK! Just switching to the physical camera was enough for now. Thank you!
