    How to make a cone with a line as the apex
    6 Posts 4 Posters 1.4k Views 4 Watching
    • G Offline
      g10338905
      I am designing cosmetic containers and having trouble making tubes such as for toothpaste and other creams (see attachment). The body of such tubes has a circular base and a line as the apex (I'm not sure what the geometric term for this shape is. Some kind of cone?).
      The way I have been making this shape is as follows:
      1. Draw a circle
      2. Push to a cylinder
      3. Scale the top circle into the thinnest ellipse possible in order to make a "line"
      4. Scale the the thin ellipse in the other direction in order to stretch the tube to the right width
      This is okay, but ideally I would like to have a single line at the top rather than a very thin ellipse.
      Is there a way to do that?
        Maybe with the Curviloft plugin... (TIG has some other lofting tools, too)
        http://forums.sketchucation.com/viewtopic.php?t=28586
        • Jean LemireJ Offline
          Jean Lemire
          Hi folks.
          See all scenes of the attached SU file for ideas.
          Tube for paste.skp
          • G Offline
            g10338905
            I tried Jean and Gaieus's solutions and both are better than what I was doing. Thanks.
            After constructing the tube, I put a label on it. I have been doing this by projecting an image from a rectangle (see attachment).
            1. Edit>Import>select image and import as texture
            2. Position image on rectangle
            3. Select Paint Bucket and click on image in the materials pallet
            4. With Paint Bucket, right-click on image>Texture>Projected
            5. Alt+click on image and then click on the tube
            Is this the best way to put a label on the tube?
              Well, at least this is the easiest way (and the only one with native SU tools). You will notice that this planar projection creates a rather "ugly" distortion of the image on the sides of the round part of that tube. Now this is mostly only visible if your image goes all around - but in case of a "normal" tube (and what I generally see), the label itself is mostly only in the middle somewhat and then it should not be as apparent as now. There is a UVTools plugin that can do cylindircal and spherical projection:
              http://forums.sketchucation.com/viewtopic.php?t=10404
              and another one which can even "unfold" geometry and you can easily apply an image to the unfolded, flat mesh and then re-apply it on the tube:
              http://forums.sketchucation.com/viewtopic.php?t=39442
              • H Offline
                Hussel Hann
                eventhough this post is quiet some time ago, i think it is a very good exercise for me.
                below is my attempt to model a "tube"
