    Layout problem - front/back order not working...
    layout
    2 Posts 2 Posters 2.4k Views 2 Watching
    • A
      adrw2001
      I'm having a sporadic issue that is quite disruptive to the Layout workflow... any help is greatly appreciated!
      Occasionally, I can't control the front/back order of elements, especially lines/dimensions drawn over the model. I can select the line and say 'bring to front', I can select the model/drawing and say 'send to back', but no matter what, the line/dimension will stay hidden behind the model...
      suggestions?!
      thanks!
      • bmikeB
        bmike
        suggestions?!
        thanks!
        Be sure to check your layers... layers at the top of the list appear above layers at the bottom.
        mike beganyi design + consulting llc
