    Turn off backfaces/two sided material assignment
    3 Posts 2 Posters 3.9k Views 2 Watching
      Mra
      Hi there,
      One of the single biggest most frustrating issue with sketchup is how it works with twosided backes/backfaces.
      Is there a way to disable two sided material assignments? There is hardly a use for it in my workflow and I find it frustrating when dealing with windows/glass as one side can be white and the other glass/transparent material.
      If there is no way to disable this, is there a script out there that will assign a material to both sides of the face throughout the model?
      Thanks. πŸ˜„
        You can't disable the two-sidedness of faces but I believe there is a plugin that will apply materials to both faces at once. Check the Plugins index via the button at the top of the forum.
          Mra
          Thanks Dave.
          For anyone else who might come across this thread in a future search:
          http://forums.sketchucation.com/viewtopic.php?t=30107
