    CAPTURE A BIG TERRAIN 3D AND TEXTURE
    5 Posts 2 Posters 1.3k Views 2 Watching
      Aboudayina
      Hi everybody,
      I dont know if ther's a thread on the automatisaton of procedures.
      I need to do repetitive treatment and I'm looking for : a plugin, a script or a "batch" to do the acquisition of a large field + (with textures in High resolution in google Earth).
      For the moment I don it manually:
      Add More imagery then I select my zone
      Select Region then I move and select my zone
      and Grab
      to get the 3D I use > Toggle Field
      thank you
        Hi Aboudayina and welcome!
        This has not been made automatic but at least there is a plugin now which allows easy (or at least easier) "stitching" the imported terrains together:
        http://forums.sketchucation.com/viewtopic.php?t=40627
          Aboudayina
          Thx Gaieus,
          it is certain that this plugin can be useful,
          but for the work I have to do it is not enough. 😳
          I have 50 km of land has captured so I really have to find the tool that will change my life.
          I'm still invegesting!
          πŸ€“
            50 km??? Are you not having clipping issues?
            http://sketchup.google.com/support/bin/answer.py?hl=en&answer=36261
            Also, are you planning to re-export anything built on this terrain to GE?
              Aboudayina
              I use SketchUp and Google Earth only for having realistic terrain and realistic road network to built ON IT in an other 3D software.
              I plan to export the FBX 3D mesh for example, merge them all in a global terrain mesh that's why the problems of clipping does not worry me.
              Also I 'm not going to export anything to GE.
