    Png overlap display bug?
    3 Posts 2 Posters 705 Views 2 Watching
    • D
      davidlouis
      I have an issue with overlaping png images.
      Basically these are trees mapped onto a surface with the intention of mutiple copies being used to create background vegetation behind a building...
      The png's have got a 'crisp' alpha masks..
      In some instances, when overlaping, they display correctly with no issues (attached image 01). From other angles, the overlap produces an additional transparent zone or 'halo' around the images which subsequently 'eclipses' the image behind it. (Images 02 & 03)
      If the skp view is exported as an image, this 'glitch' is evident...
      Interestingly, if one cycles through objects, selecting them one at the time, the display issue is temporarily resolved on the object directly behind that selected!.....???
      Has anyone experienced this? Could it be a graphics card issue? Do you know a trick to correct it?
      Thanks in advance...
      Dave
      • GaieusG
        Try to set your transparency to "nicer" under Styles > In model > Edit > Face settings...
        There will always be some halo in SU but hopefully it can be minimized. It can slow down SU considerably however (with lots of transparent things)
        • D
          davidlouis
          Thanks Gaieus
          Working just fine now... πŸ˜„
          Even Medium seems to do the trick...
          Thanks πŸ‘
