    Awkward Corner
    4 Posts 3 Posters 278 Views 3 Watching
      ainsinnes
      Hey there,
      Currently in the process of building the SU model for a university project and have hit a bit of problem.
      Here is a link to screen grab of the current situation:
      http://a5.sphotos.ak.fbcdn.net/hphotos-ak-ash4/298009_10150878093925226_553205225_21384663_183251351_n.jpg
      Essentially I need these curves to form a continuous profile along the full length of the object; hopefully that makes sense. I was wondering if somebody knew a more elegant solution than deleting the triangular bit an 'stitching' the each segment of the circle manually. It does fill the gap but is very messy and i'm hoping to render this model in 3DMax, so the the simpler the better.
      Any help or advice would be greatly appreciated.
      Thanks in advance
      • mitcorbM Offline
        mitcorb
        Hi, ainsinnes:
        May I make the suggestion that you post the model if possible into your reply as a .skp file?
        In the meantime, I am assuming you want a rounded edge continuous on the top perimeter? Or, is the object in the background an idea of the finished item?
        Maybe elaborate a bit on what you need. I see several possible interpretations to your request.
          d12dozr
          If I understand what you need, it looks like a simple matter for Fredo's Round Corner plugin, or even just plain old "Follow Me"
          Here's how to do it manually with Follow Me:
          http://goo.gl/f7ooYh
            ainsinnes
            @d12dozr, thanks very much for the advice, that worked a treat. @mitcorb obviously my question has been answered, but cheers for posting. I'm rather new to this forum business, so I appreciate your suggestion and I'll endeavour to be more informative in future.
            Thanks again,
