    Please help me create this shape!!!!!!!
    Scheduled Pinned Locked Moved Organic Modelling
    18 Posts 11 Posters 11.8k Views 11 Watching
    • N Offline
      nguhait
      Hi guys! I'm been using sketchup for a while now, but never know how to make organic shape...I'm been trying and youtubing how to do but many attempts failed. I'm doing a project and I want to made this bed to a sofa for 8-10 people. I love the shape of it, but instead of a bed i want it to be like a half round sofa.
      Please Please help!!!!!!!!!!!!!!
      • Alan FraserA Offline
        Alan Fraser
        Use Boolean subtraction. Make a complete 'egg' shape by lathing a profile around an axis. Then create another shape that will intersect the egg and remove the amount of material necessary to create the shape you want. Use the Solid Tools on the Tools menu to subtract the one from the other. If you then want to give the result some solidity, you can use Fredo's Joint Push/Pull script to extend it inwards.
        Boolean.skp
        3D Figures
          Take 2 spheres or more
          Scale them on x or y one less than the other
          And make some Boolean operations (if you have the pro version)
          Else make some Intersections by hand πŸ˜‰
          here right Click / intersection by hand with 2 Half spheres scaled
          Repeat this operation and you will obtain with no difficulty your form wanted! πŸ˜‰
          • H Offline
            helios
            Is it possible to do this without intersecting first? I.e. can you just draw an egg shape (which would be hollow inside) and then use the Joint Pull/Push tool to give the egg shell some thickness? Once that's accomplished, you should be able to cut out holes in the shell by drawing segments on surface and removing them.
            • Jean LemireJ Offline
              Jean Lemire
              Hi folks.
              See this SU file for ideas.
              Egg shaped sofa.skp
              It goes along Alan's idea but I create the egg shape with a double wall first, thus avoiding the use of a plugin.
              Just ideas.
                leminilab
                I'm learning how to use Artisan at the moment so I gave it a try.
                Here's what I have so far:
                egg bed.skp
                Hope this helps. πŸ˜„
                • "Live every day as if it were your last and then some day you'll be right."
                • "ThomThom rules!!!"
                  leminilab
                  Hi!
                  Well I took some time to refine my proxy and came up with this:
                  lomme bed.zip
                  I think it's getting closer to the original but I'm wondering if there's a better/simpler way to achieve this than what I did?
                  • jo-keJ Offline
                    jo-ke
                    first I created a sphere, then I streched it to an egg- shape. Then I painted an elipse with tools on surface and deleted the faces. I did the same on the backside. I doubled the egg and scaled it to the inside size and placed it inside. I exploaded the two components and selected the inside and outside elipses. Then I connected the two selected lines. make component, ready.
                    http://www.zz7.de
                    • numbthumbN Offline
                      numbthumb
                      And then a girl got exposed a bit more πŸ˜„
                      Are those Poser models?
                      Comfortably numb...
                      • jo-keJ Offline
                        jo-ke
                        no google warehouse:
                        http://sketchup.google.com/3dwarehouse/details?mid=8e043725676ec370ccf47772b6258cbf&prevstart=0
                        http://www.zz7.de
                          Another method will be make some curves section and then use Curviloft by Fredo6 πŸ˜‰
                            rspierenburg
                            I made an egg, made a copy, scaled the copy out a little. Then using two planes and intersect with selection I was able to create this.
                            Rob
                            Egg
                              Hai, please, post the same topic only once. You will only cause confusion if there are two, parallel, identical topics (now I merged them and deleted one of your posts)
                              • N Offline
                                nguhait
                                BIG THANKS to everyone that spend sometime and effort to help me created this model. They look super cool.I'm very new at sketchup so its going take me sometime to understand you guys methods. πŸ˜„ but i'm very thankful for the education.
                                • N Offline
                                  nguhait
                                  Can anyone help me cut out the hatched parts on the drawing? I was trying to make this bed to a round sofa but couldn't never get it right...
                                    Draw a cylinder and make a boolean Diff operation
                                    • N Offline
                                      nguhait
                                      wow that was super easy. Thanks Pilou
                                      • david_hD Offline
                                        david_h
                                        Hardly instructive I would think. . .but I did this quickly just to see if I could do it. (That is always the measuring stick after all! See my signature tag line below! πŸ’š )
                                        The shape probably isn't dead on to the picture, but
                                        I drew a sphere. Cut it in half. JPP. drew a cylinder. Tweaked the shape with Fredo Scale.
                                        Bool Tools or solid tools Difference operation.
                                        Tweaked the shape some more with Fredo scale.
                                        I am sure it could really beautifully massaged (no pun intended) with Artisan or More FredoScale tool tweaking.
