    Please help me create this shape!!!!!!!
    Scheduled Pinned Locked Moved Organic Modelling
    18 Posts 11 Posters 12.1k Views 11 Watching
    • jo-keJ
      jo-ke
      first I created a sphere, then I streched it to an egg- shape. Then I painted an elipse with tools on surface and deleted the faces. I did the same on the backside. I doubled the egg and scaled it to the inside size and placed it inside. I exploaded the two components and selected the inside and outside elipses. Then I connected the two selected lines. make component, ready.
      http://www.zz7.de
      • numbthumbN
        numbthumb
        And then a girl got exposed a bit more πŸ˜„
        Are those Poser models?
        Comfortably numb...
        • jo-keJ
          jo-ke
          no google warehouse:
          Error 404 (Not Found)!!1
          (sketchup.google.com)
          http://www.zz7.de
            Another method will be make some curves section and then use Curviloft by Fredo6 πŸ˜‰
              rspierenburg
              I made an egg, made a copy, scaled the copy out a little. Then using two planes and intersect with selection I was able to create this.
              Rob
              Egg
              • GaieusG
                Hai, please, post the same topic only once. You will only cause confusion if there are two, parallel, identical topics (now I merged them and deleted one of your posts)
                • N
                  nguhait
                  BIG THANKS to everyone that spend sometime and effort to help me created this model. They look super cool.I'm very new at sketchup so its going take me sometime to understand you guys methods. πŸ˜„ but i'm very thankful for the education.
                  • N
                    nguhait
                    Can anyone help me cut out the hatched parts on the drawing? I was trying to make this bed to a round sofa but couldn't never get it right...
                      Draw a cylinder and make a boolean Diff operation
                      • N
                        nguhait
                        wow that was super easy. Thanks Pilou
                        • david_hD
                          david_h
                          Hardly instructive I would think. . .but I did this quickly just to see if I could do it. (That is always the measuring stick after all! See my signature tag line below! πŸ’š )
                          The shape probably isn't dead on to the picture, but
                          I drew a sphere. Cut it in half. JPP. drew a cylinder. Tweaked the shape with Fredo Scale.
                          Bool Tools or solid tools Difference operation.
                          Tweaked the shape some more with Fredo scale.
                          I am sure it could really beautifully massaged (no pun intended) with Artisan or More FredoScale tool tweaking.
