    Second attempt Maxwell Render + Sketchup
    18 Posts 6 Posters 1.8k Views 6 Watching
      sexydevil01
      I have been messing around for years with Form-Z, within the last few months I have got totally hooked on Sketchup & Maxwell. So here are my second attempt renders with Maxwell Render, i was on a deadline but i was really impressed with Maxwell. Still working on the night shot, I am not impressed with the lights reflecting back on the pool water surface. Any tips on this will be much appreciated. I am slowly moving away from Form-Z and now i find myself falling back on the powers of sketchup. Any C&C welcome.
      Entrance Lobby
      Infinity Pool & sea view
      Dining room & Living room opening out to pool
      Test night scene
        davidh
        I would suggest you use a HDRI for the environment lighting,particularly for any late evening/early morning shots that include lights.The difference in lighting between using a HDRI and the standard environmental set up can be very dramatic.Also ,depending on the colour tones in the HDRI,you can get additional colours reflecting in the pool.The HDRI dosent have to be that large in file size to get a decent effect.
          sexydevil01
          Thanks... For the night scene I have used a HDRI for the environment lighting, maybe I need to try a different image or tweak the settings. I am still learning to use Maxwell 😞 I guess it is all a process of trial and error. I saw your 'sunset' post, pretty amazing πŸ‘
            cadmunkey
            These look good, will be interested to see any new images if you take Davids advice and try some HDRIs. I remember trying Maxwell out a long, long time ago but it was far too slow back then for it to be a viable option for me. Whats it like these days, much improved I hope!
              sexydevil01
              Hi, Thank you. I am going to try Davids advice, will post images when ready. I am new to Maxwell but I am happy with the speeds, the above renders took about 2 hours per scene.
              • Bryan KB Offline
                Looking good!
                  sexydevil01
                  Thank you.
                    sexydevil01
                    David, thanks to your advise, I think I am getting there. Any C&C welcome.
                    Sunset scene
                    My take on Barcelone Test render
                    Test DOF & lighting
                      davidh
                      I think these are definitely more successful but if you have photoshop,you should increase the Curves in order to brighten up the images.Often I place a colour band layer in photoshop on my original render,blended using "soft light".
                      This has the effect of really pulling out the colours.This colour band can be also be used for indoor shots,particularly where you may have blank,white walls.It can make a big difference.
                      I have attached the colour band jpeg that I usually use,along with your barcelona image post processed.
                      The steps I used in post processing were:
                      1.Increased curves
                      2.Added the colour banding jpg,layer blended "softlight" 50%
                      3.Merged layers
                      4.Duplicated the image and used the pull down IMAGE/ADJUST/AUTO COLOUR).Then layer blended "Normal" 40%.
                      By the way,the compostion of the barcelona image works really,really well.
                      I hope this helps
                        sexydevil01
                        WOW πŸ‘, Thanks a million. This really helps & it does make a huge difference to the render. Thanks once again for sharing your knowledge.
                          Stevo
                          Hi all. I've just joined the forum and have been checking out all the great work. I also was using Maxwell. A great compliment to Sketchup. Sadly the work-flow at the office doesnt play well with Maxwell as a result the long time it takes and the learning curve. I wish I had more time to devote to it. This was a project I did a few years ago. It was acually a development in Florida but these images suggest the Middle East or Africa theme. Thanks to whoever shared the Land Rover on the 3D warehouse. TheBrewery was another project in boston.
                          OS/Hardware:
                          Win7 64
                          Sager NP7280
                          i7 980x
                          SLI 460M
                          12gb
                            sexydevil01
                            Hi Stevo,
                            Welcome to the forum.
                            I like the render you posted, it is unfortunate that you cannot pursue with Maxwell. I personally am very pleased with Maxwell.
                            • brodieB Offline
                              brodie
                              Looks good. I've been using SU+Maxwell for a few years now and it's always good to see someone else catching the bug.
                              One tip I'd give you for the water would be to use a bump map so it's not quite so perfectly smooth. That'll distort those reflections a bit and add a lot of realism.
                              -Brodie
                                Stevo
                                Hi All thanks for the comments. I think I'll try one more time to get the office to purchase the latest release. Are you guys using the new version? Hows the plugin work? Brodie, what water are you referring to? I like the idea a lot... I was thinking the image could use sand storm and wind, any ideas on how I could do that in Photoshop?
                                OS/Hardware:
                                Win7 64
                                Sager NP7280
                                i7 980x
                                SLI 460M
                                12gb
                                  Stevo
                                  Heres the night image
                                  OS/Hardware:
                                  Win7 64
                                  Sager NP7280
                                  i7 980x
                                  SLI 460M
                                  12gb
                                    Stevo
                                    Heres one of a brewery project I did for fun.
                                    OS/Hardware:
                                    Win7 64
                                    Sager NP7280
                                    i7 980x
                                    SLI 460M
                                    12gb
                                    • brodieB Offline
                                      brodie
                                      I was referring to the OP's pool water, particularly the 2nd rendering in his first post.
                                      -Brodie
                                        Stevo
                                        All this stuff got me hot for more Maxwell. Seems I have good timing; the boss is in a good mood, can you say upgrade, yeah!
                                        OS/Hardware:
                                        Win7 64
                                        Sager NP7280
                                        i7 980x
                                        SLI 460M
                                        12gb
