    โš ๏ธ Important | Libfredo 15.8b introduces important bugfixes for Fredo's Extensions Update
    Second attempt Maxwell Render + Sketchup
    18 Posts 6 Posters 1.7k Views 6 Watching
      sexydevil01
      Thank you.
        sexydevil01
        David, thanks to your advise, I think I am getting there. Any C&C welcome.
        Sunset scene
        My take on Barcelone Test render
        Test DOF & lighting
          davidh
          I think these are definitely more successful but if you have photoshop,you should increase the Curves in order to brighten up the images.Often I place a colour band layer in photoshop on my original render,blended using "soft light".
          This has the effect of really pulling out the colours.This colour band can be also be used for indoor shots,particularly where you may have blank,white walls.It can make a big difference.
          I have attached the colour band jpeg that I usually use,along with your barcelona image post processed.
          The steps I used in post processing were:
          1.Increased curves
          2.Added the colour banding jpg,layer blended "softlight" 50%
          3.Merged layers
          4.Duplicated the image and used the pull down IMAGE/ADJUST/AUTO COLOUR).Then layer blended "Normal" 40%.
          By the way,the compostion of the barcelona image works really,really well.
          I hope this helps
            sexydevil01
            WOW ๐Ÿ‘, Thanks a million. This really helps & it does make a huge difference to the render. Thanks once again for sharing your knowledge.
              Stevo
              Hi all. I've just joined the forum and have been checking out all the great work. I also was using Maxwell. A great compliment to Sketchup. Sadly the work-flow at the office doesnt play well with Maxwell as a result the long time it takes and the learning curve. I wish I had more time to devote to it. This was a project I did a few years ago. It was acually a development in Florida but these images suggest the Middle East or Africa theme. Thanks to whoever shared the Land Rover on the 3D warehouse. TheBrewery was another project in boston.
              OS/Hardware:
              Win7 64
              Sager NP7280
              i7 980x
              SLI 460M
              12gb
                sexydevil01
                Hi Stevo,
                Welcome to the forum.
                I like the render you posted, it is unfortunate that you cannot pursue with Maxwell. I personally am very pleased with Maxwell.
                • brodieB Offline
                  brodie
                  Looks good. I've been using SU+Maxwell for a few years now and it's always good to see someone else catching the bug.
                  One tip I'd give you for the water would be to use a bump map so it's not quite so perfectly smooth. That'll distort those reflections a bit and add a lot of realism.
                  -Brodie
                    Stevo
                    Hi All thanks for the comments. I think I'll try one more time to get the office to purchase the latest release. Are you guys using the new version? Hows the plugin work? Brodie, what water are you referring to? I like the idea a lot... I was thinking the image could use sand storm and wind, any ideas on how I could do that in Photoshop?
                    OS/Hardware:
                    Win7 64
                    Sager NP7280
                    i7 980x
                    SLI 460M
                    12gb
                      Stevo
                      Heres the night image
                      OS/Hardware:
                      Win7 64
                      Sager NP7280
                      i7 980x
                      SLI 460M
                      12gb
                        Stevo
                        Heres one of a brewery project I did for fun.
                        OS/Hardware:
                        Win7 64
                        Sager NP7280
                        i7 980x
                        SLI 460M
                        12gb
                        • brodieB Offline
                          brodie
                          I was referring to the OP's pool water, particularly the 2nd rendering in his first post.
                          -Brodie
                            Stevo
                            All this stuff got me hot for more Maxwell. Seems I have good timing; the boss is in a good mood, can you say upgrade, yeah!
                            OS/Hardware:
                            Win7 64
                            Sager NP7280
                            i7 980x
                            SLI 460M
                            12gb
