    [Plugin] Equal Segments
    3 Posts 3 Posters 6.5k Views 3 Watching
    • TIGT
      This pair of tools draws fixed length segments.
      One draws a straight section and then a given radius 'arc' section each with a specified number of segments - with all segments the same length.
      The other draws an 'arc' of a set sweep, segment length and number of segments - calculating the radius for you...
      Place the .rb files in the Plugins folder and restart Sketchup...
      You use each by entering its command in the Ruby Console + <enter>
      TIG.equalsegs
      and then enter values in a dialog.TIG-equalsegs.rbTIG-equalsegs.PNGor
      TIG.equalsegssweep
      and then enter values in a dialog.TIG-equalsegssweep.rbTIG-equalsegssweep.PNG
      If you MUST have a menu item add this code between the last two 'end' lines in the script
      menu=UI.menu("Draw").add_item("TIG-equalsegs"){TIG.equalsegs()}unless file_loaded?(File.basename(__FILE__))
      file_loaded(File.basename(__FILE__))
      You can change 'Draw' menu name to whatever other menu you want... and obviously you change 'equalsegs' to read 'equalsegssweep' for the other tool ! PayPalButton
      • GaieusG
        You're too kind, TIG! πŸ˜‰
          and for select all segments with a length given By Chris Fullmer πŸ˜‰
