    How to use ruby console
    4 Posts 4 Posters 5.0k Views 4 Watching
    • M
      mdhelmi84
      how to make dotted-line bounding box bigger than usual?
      the idea is to highlight the selected component by using edit group feature..without dotted-line bounding box being seen
      somebody said use ruby console but dont know how to use it
      please teach me...
      • mitcorbM
        mitcorb
        First step: Open Sketchup, on the top "ribbon" Window>Ruby Console can be found in the drop down. I cannot tell you what to put in or take out. If you wish to do ruby coding, there are two other subforums. Developers Forum and Plugins Forum. Hope this helps?
        • A
          Aerilius
          I have looked and tried in SketchUp, but I don't have a clue at the moment what the dotted-line bounding box is? (in SketchUp, not Layout)
          It's a good idea to first set the goal and precisely describe what you want to achieve (how it should look like etc.). Then later one can think of a possible technical solution ("using edit group feature" or something else), depending on what is possible with the Ruby API.
          Reference to SketchUp's Ruby API is here: http://code.google.com/intl/de-DE/apis/sketchup/docs/index.html
          If you have never done anything similar like scripting or never used a console, I would recommend to take some time to get used to it. It's a bit more to learn than clicking on some toolbar buttons, but you shouldn't fear the console.
          There is a great tutorial by Martin Rinehart for beginners:
          http://www.martinrinehart.com/models/tutorial/tutorial_11.html
          It uses a plugin "SketchTalk" that teaches you Ruby (you have to download the plugin first).
          • Wo3DanW
            Wo3Dan
            If you are the same person who asked in Google SketchUp Help Forum (see: http://www.google.com/support/forum/p/sketchup/thread?tid=5bab09c14b74fa86&hl=en ) that hint I made about using the ruby console is purely speculation. I don't know (as mentioned) if such a command line is possible at all. One of the ruby scripters here might know.
            What I ment was to (if possible) disable displaying the bounding box by code.
            It would be like disabling the screen texts Top / Front / etc. for standard views.
            See/open SU's menu Window > Ruby Console and copy next sentence:
            Sketchup.active_model.rendering_options["ShowViewName"] = false
            in the console and [Enter] From now on Top etc. isn't shown on screen.
            (paste:
            Sketchup.active_model.rendering_options["ShowViewName"] = true
            to enable again.)
            Once again, there might exist something similar for the bounding box. Although I'm far from sure about it.
            The purely SketchUp solution with fog is a (not so elegant) workaround.
