    Color components
    10 Posts 5 Posters 638 Views 5 Watching
      blue_orchid
      ents = Sketchup.active_model.entities[0]
      ents.entityID
      Result-2345
      Now, I need to assign the color 'red' to this particular component whose entityID is 2345. How should I do it?
        Jim
        You already have a reference to the entity, so it is as simple as:
        ents.material = "Red"
        If you need to search for that entity again, then the following may work (unless you need to dig into sub-components:)
        Sketchup.active_model.entities.each {|entity|
          if entity.entityID == 2345
             entity.material = "Red"
             break
          Jim
          The previous example takes advantage of a feature of the .material= method which can accept a color name as an argument. You can view the available color names by entering Sketchup::Color.names in the Ruby Console window.
          If you want to use a custom color or texture, you need to add a new material, then assign it a color or texture.
          mat = Sketchup.active_model.materials.add("New Material") mat.color = Sketchup::Color.new(red, green, blue, alpha) ents.material = mat
          Note all parameters to the Color.new method are optional.
            What are you using entityID for? Note that it's not a reference that last across sessions.
              Another minor point on 'idiom' - to make it easier for us to help debug your code please use logical names.
              If you get ALL of the entities in a selection as an array use
              ent**s**=model.selection.to_a
              The 's' on its name helps us/you realize/remember that it's an array of several objects...
              Then use
              ents.each{|ent| ent.material='Red' if ent.class==Sketchup::Face and e.normal.z==0 }
              To process each one in turn... Where logically ent is one of the things in the collection called ents
              To get the first thing selected therefore use a 'single' name like
              ent=model.selection[0]
              NOT a plural 'ents' which suggests to many that it's a collection...
                blue_orchid
                Thanks to everyone!!!
                What should be the script If I have to add the new parameter like width=='1'? This parameter 'width' is a category from MySQl database.
                if entity.entityID == 2345 and width=='1'
                entity.material = "Blue"
                break
                • Chris FullmerC Offline
                  well, that depends. Do you just want to assign an attribute called "width" to an object? Or do you actually want to make that object be a specified width? I suppose the same also hold true for the color. Now I remember you're doing the database interaction.
                  All my Plugins I've written
                    blue_orchid
                    It's kind of both.
                    The component is assigned 'width' attribute and, also parameter 'width' is pulled out from database.
                    I am doing process by process. Right now, i am taking the parameter 'width' from db and coloring each component different colors. Like assigning Component1 with ID 2345 and width 10" a 'red' color, Component2 with ID 2343 and width 12" a 'blue' color and so on......
                      You're storing entityID in a database?
                        IDs do not subsist across sessions as they are re set every time the SKP opens.
                        You must give entities attributes which will be carried across sessions to find them successfully...
