    Methods/suggestions? Man in a net trap!
    5 Posts 4 Posters 293 Views 4 Watching
      CalypsoArt
      I know SU is not the best application for this but It's what I have to work with at the moment. I need to create a figure trapped in a net. Yep that fake movie "he stepped in a trap" net. I was thinking of using sandbox to shape it but I'm open to suggestions of other methods. The end result should be just what you've seen umpteen times in movies. The net needs to be dimensional but can't have faces obscure the figure.
        driven
        hi,
        I'd probably grab a 3d figure off the Warehouse and position it how I imagine the man should appear,
        then build a wireframe mesh around that to my hanging point, if these are grouped in bottom to top lengths you can later use follow me, or tubes/pipe along path to make your rope.
        fun idea, shame I need sleep...
        john
        • mitcorbM Offline
          mitcorb
          You might have to scale this way up. I have experimented with wrapping objects with tubes. What about that Sketchup Ivy plugin? Can you generate a net with that?
          • brodieB Offline
            brodie
            Not quite sure what the best way would be to make the net but I'd recommend just getting it fairly close and then using the FFD script to fine tune its overall placement.
            -Brodie
            • mitcorbM Offline
              mitcorb
              Maybe treat it as a tablecloth, to drape, so to speak, and model it upside down. Mindful that the dangling portion will need to be cinched up, or gathered. Now, I am thinking that you may approach this like modeling a teardrop. That suggests that you could start with a basic Sketchup UV sphere or a Geodesic sphere as one element, extend it, or stretch it, or scale it upward, form a 2d profile resembling gathered fabric, progressively/ sequentially pushpull and scale for a "few" reps, then tie a rope around it when you get tired. That's probably what I would try, without getting into plugins.
