    Sketchup Layer Control in Layout?
    layout
    4 Posts 2 Posters 3.6k Views 2 Watching
    • dshafferD Offline
      dshaffer
      Hi -
      I think I know the answer to this question, but will go ahead and ask it.
      Is it possible to turn Sketchup Model layers on and off from within Layout? If not, this seems to be a big oversight to me.
      Thanks -
      Doug
      Doug Shaffer
      McHenry Shaffer Architecture
      Sketchup Pro 2021, Vectorworks 2021, Mac
      • utilerU Offline
        utiler
        Hi Doug,
        Unfortunately, you can't. That is what scenes are for in SU I guess; to be able to set particular levels of communication then view then in LO. I only thought about this very issue last night and thought it would be great to be able to manipulate SU layers from with LO though!!
        πŸ‘
        Just Curious...
        • dshafferD Offline
          dshaffer
          Bummer. It seems odd to me that Layout allows manipulation of view rotation, shadows, fog, etc. but not Sketchup layers. I have only recently started using Layout, but this is a capability that should be added in the future.
          For example, I want to simply be able to rotate a view of "Concept A" in Layout, duplicate the page, then show "Concept B" at the EXACT same angle. This could be done if I could turn off Sketchup layer "Concept A" and turn on Sketchup layer "Concept B" from within Layout.
          On a similar note, Layout gets a bit glitchy if NOT all of the boxes in "Properties To Save" in the Sketchup Scenes pallet are checked.
          For example, I have made Sketchup scenes showing views from different angles of a building renovation / addition where the "Layers" are not affected by a change in the scene (the "Layers" box is NOT checked in the "Properties To Save" portion of the scenes panel). I have made design concepts 'A' and 'B' and set up scenes called "Concept A" and "Concept B" in which ONLY the Layers property is saved. This allows me to make 20 different views (scenes) of each concept and have only 22 scenes generated. If I want to make Concept 'C', I simply make another scene called "Concept C" in which ONLY the Layers property is saved and I'll have the ability to see the same 20 views of that new scheme, too. Does that make sense?
          As a result, Layout doesn't know what to do with any of the scenes that I have set up in my Sketchup model.
          Doug Shaffer
          • utilerU Offline
            utiler
            Doug, just create your scenes with geometry actively viewed as needed then bring into Layout. KEY: make sure you have background ground, sky OFF so only the model shows.
            From there make a copy of each scene and 'Arrange them as you want to view them. ie: stack the views to show one behind the other...
            I think that's what you want to do, yeah?
            Just Curious...
