    Ruby Equivalent of Move/Copy
    6 Posts 3 Posters 4.0k Views 3 Watching
    • K Offline
      kybasche
      Hey all.
      I have a general understand of how to move entities using transformations.
      But here's what I don't know how to do.
      I have a group.
      group_shell=model.active_entities.add_group()
      ents=group_shell.entities
      points_box=[[0,0,0],[5,0,0],[5,10,0],[0,10,0]]
      face_box=ents.add_face(points_box)
      face_box.pushpull(-20)
      I'd like to make a copy of that group and move it to a different location. (I want two identical boxes sitting next to each other)
      (yes, it's more complicated than just a box πŸ˜‰ )
      That's it.
      Any hints?
      Thanks!
      Derek
      • sdmitchS Offline
        sdmitch
        kybasche,
        group_shell_copy=group_shell.copy#create a copy
        tr=Geom;;Transformation.new([10,0,0])#copy location
        group_shell_copy.transform! tr
        http://sdmitch.blogspot.com/
        • K Offline
          kybasche
          Brilliant!!
          Thanks sdmitch.
          • TIGT Online
            One of the problems with using the standard group.copy method is that there are a few rogue scripts out there that mess with the function because they ill-advisedly change built-in classes/methods or have poorly formed observers etc - e.g. SketchyPhysics and DrivingDimensions... As some of these are popular it's best to avoid the .copy method in a distributed script, where you have no control over what other tools the user has installed...
            I forgot and had to recast SuperDrape the other day and I also remade Mirror a while ago too.
            The alternative way produces the same result...
            group_copy = group.copy
            becomes
            group_copy = group.parent.entities.add_instance(group.entities.parent, group.transformation)
            I know it's a lot more convoluted BUT it does the same thing and doesn't seem to have issues with other scripts so much πŸ˜’
            In you case you can do the [predefined] transformation as you add the instance
            group_copy = group.parent.entities.add_instance(group.entities.parent, tr)
            • sdmitchS Offline
              sdmitch
              TIG, Thanks for the info. As many times that I have searched through the Ruby API Document, I never saw that .add_instance could be applied to groups. It's always a good day when you learn something new.
              • TIGT Online
                You can only use entities.add_instance() of a definition, BUT there's no built in group.definition method πŸ˜’ , BUT all components, groups and images are all just types of instances of a definition.
                To find a group's definition you have to find its entities' parent which is the definition - so
                defn = group.entities.parent
                ComponentDefinition
                just as the much snappier method defn = instance.definition does for a component-instance !
                The second argument of the entities.add_instance(defn, **tr**) is the transformation used to place/manipulate the new instance...
