    Folding/Unfolding sections
    3 Posts 2 Posters 379 Views 2 Watching
      anbar
      One of the things i use Sketchup for is to design etch-brass model parts: I make the item in "3D" then ahve to fold out the various pieces onto the same plane so that i can then generate a flat pdf of the parts.
      Is there a plugin that allows you to fold/unfold parts without haivng to do everything manually with the rotate key?
        There are a few plugins for unfolding. Jim's Unfold is one and then there's Flattery. As far as refolding, I'm not aware of any.
          anbar
          sounds ideal - TVM! πŸ˜‰
