    Reverse Face if side clicked on is the back.
    5 Posts 3 Posters 429 Views 3 Watching
    • B
      byrnebm
      Does anyone know how I could programmatically check what side of a face I have clicked on and if it is the back side of a face it gets reversed? So basically I click on a number of faces and for the ones that I have clicked on the back side of, they get flipped. Thanks
      • TIGT
        There are already several 'reverse face' tools from which you can glean info...
        Of course if they are connected the built-in 'orient' will endure they all flip to match a selected correctly facing one without any selection needed.
        However, specific to your question - the only 'trick' I can think of would be to get the picked face.normal and if the angle between that and the vector from the picked 3d point to the model.active_view.camera.eye is more that 90 degrees you have probably clicked on the back face, so it's to flip... You have to 'flip as you pick' because the angle will change as the user orbits.
        If you want to preselect faces then those with faces > 90 degrees normal/eye-vector angles will be flipped BUT this relies on the camera position at the moment the tool activates...
        • TIGT
          See this http://forums.sketchucation.com/viewtopic.php?p=357136#p357136
          • T
            tomasz
            or FrontFace.
            • TIGT
              or FrontFace.
              Sorry Tomasz - I had overlooked your similar tool - there are indeed lots to choose from πŸ˜‰
