    [Request] Batch DXF Export
    6 Posts 3 Posters 2.3k Views 3 Watching
    • dereiD Offline
      derei
      I noticed that are several DXF-import plugins, but nothing to export.
      Would it be possible to create a plugin for SU Free that exports DXF from selected components/groups, but each component/group to be saved as different DXF file? Also to be able to choose faces/edges/DXF version ?
      Thank you very much.
      DESIGNER AND ARTIST [DEREI.UK](http://derei.uk/l)
      • dereiD Offline
        derei
        Nobody interested in this?
          driven
          guitar list has an exporter that works in 'free'
          the forum there may have info for batch export, I only ever export individual items, one at a time.
          john
          http://www.guitar-list.com/forums/sketchup-plugins
          • dereiD Offline
            derei
            john
            One at a time would be fine, but sketchUp doesn't allow exporting just a part of model. I tried to export only what was inside a component, but it ended with a dxf containing the entire model 😞
              driven
              it does on the mac?
              if you only have 'one' component or group selected (but not open for editing),
              just to check I pulled a 75KB DXF out of a 8MB drawing.
              but, I more often copy>> paste in place what I want to export into it's own new drawing first and get it exactly right, without interfering with my main file.
              john
                I wrote this a while ago - it exports a selection to any available format http://forums.sketchucation.com/viewtopic.php?p=183756#p183756
                So in your case it'd be export_selection('dxf')
                Of course you need the appropriate exporter - so for DXF you need v8Pro on one of the earlier versions that came with it in Free...
